BRAKE VAN
Re: BRAKE VAN
Did it all myself, luckily I have access to a laser cutter. After doing a rough sketch to flesh out some dimensions I drew it using 2D Design. Mostly cut out of 3mm laser ply and 1.5mm birch ply. I am happier now that I have resprayed it grey. Its a 95p can of Battleship Grey from Buyology, the whole can allowed me to give it three coats. I have also now covered the roof in Solartex and sprayed it with white primer before the final coat of a slightly off white.
20170814_163439 by Jonathan Demery, on Flickr
Re: BRAKE VAN
Yes - can see your pics now - the green looks good but I'm a grey or bauxite red guards van man!
Re: BRAKE VAN
Thanks for editing the posts, I can now see the pictures and very good they are too! Nice looking vehicle and well built.
Re: BRAKE VAN
Thank you for the pics. I agree with the grey too, a real service colour.
Re: BRAKE VAN
Some updates
I have cut out some decals using white gloss vinyl, before cutting I flatted back an area using 1200 grade wet and dry. Once fitted I made sure to rub the letters into the planking detail using a cocktail stick. The main body was then given an all over coat of Humbrol clear matt aerosol. Running boards, underside, axle boxes etc were then painted using brush on black acrylic. I used a selection of weathering powders to give a feeling of wear and tear, this was finished off with a dusting of satin clear varnish. The roof as mentioned before was covered in Solartex fabric, this was then sprayed white and weathered using powders again and coated in clear varnish. Interior has been painted white and stained laser cut floorboards installed. I have also added some windows.
20170819_184137 by Jonathan Demery, on Flickr
20170819_184203 by Jonathan Demery, on Flickr
Next job detail the interior maybe add some lighting and install the chimney. Hopefully, you can all see the pictures as I have tried a different setup.
Re: BRAKE VAN
Constant improvement and attention to detail.... love it!
Re: BRAKE VAN
Nice subtle weathering job, and those letters and numbers are very professional looking. Did you set out and cut them entirely by hand? top job!
Re: BRAKE VAN
Thanks all for the positive comments, it's my first full scratch build apart from some fixtures (axle boxes, wheels and buffers) as I am a newbie railway modeller, I have built plenty of RC gliders though.
LNR re the letters, I cheated slightly as I have access to a Roland Camm 1 in work.
- Busted Bricks
Re: BRAKE VAN
It looks great, well done.
