16mm and its relationship with other scales
Dwayne
Post by Dwayne » Sun Mar 12, 2017 5:09 pm
artfull dodger:123448 wrote:Dealing with the high cost for a live steamer was the major hurdle I had to get past when I shifted to 16mm vs track powered LGB style garden railroading.  I still long for a brand new Lady Anne from Roundhouse, maybe some day! For now my venerable Merlin Major keeps trains moving.  Now if sourcing 32mm Peco track wasn't so hard on my side of the pond.   Still running over German girder rails for now.  A new raised line is in the planning stages and the hope is for 32mm gauge at that time instead of 45mm.     There are so many ways one can model 16mm in the garden, thats one of the major draws to me.  Espiclly overgrown moss covered tracks!    Mike
Mike, why not hand lay your own track? It's not difficult.
Llagas Creek Railways offers six foot long lengths of Code 215 or 250 (I use Code 250) for $3.90/piece. If my math is correct, that's $1.30 per foot just for the rail (without included shipping charge). I rip my own ties from pressure treated 5/8"x 6" x 6ft fence pickets at Home Deport for $1.55 each which yields about 70-75 ties per picket, or 2¢ per tie.
artfull dodger
Post by artfull dodger » Sun Mar 12, 2017 5:25 pm
I have thought about it, lack the means to rip my own ties and while my friend says he will make the ties(we were thinking about 7/8ths scale as well), I wont hold me breath. He would rather hold down his chair these days. Also, point work construction scares me, even with premade frogs and point rails. Let me see if I get past the raised roadbed construction first. There is a raised line I am watching over in the "railway" part of this forum. Mine will be higher off the ground, but the style he is using is exactly what I had in mind for the shelf/track support idea. Waiting on local dealer to see if he can get SM32 Peco track, it isnt listed in the normal USA catalog other than a referance picture among pictures of all thier track offered. Thier SM45 is in there though! Mike
Killian Keane
Post by Killian Keane » Sun Mar 12, 2017 5:39 pm
I have a suggestion for homemade points, not the most prototypical but bear with me, turntables on a curved section of track so that by rotating 180 degrees one changes direction, I got the idea from the lartigue monorailway where actual pionts are impossible, an archaic idea, but it might just work
Dwayne
Post by Dwayne » Sun Mar 12, 2017 6:06 pm
Don't be afraid to try it. I've build standard switches, curved and wyes. Nice thing about large scale rail is that you can build like the prototype does using nearly the same techniques. Frogs seem complicated but essentially it's a simple matter of cutting, bending and filing the rail then assembling like a puzzle.
Photo here of my most complicated switch build so far. A curved 12" radius switch up against a standard 12" radius switch with a curved/straight crossing added into the mix. Took me a few days to get this built. :)
Dr. Bond of the DVLR
Post by Dr. Bond of the DVLR » Tue Mar 21, 2017 12:12 am
Chris Cairns:123413 wrote:
TonyW wrote:There are many in 16mm who do the same thing.
As commented on by a fellow 16mm NGM member last week regarding some of running in the latest 16mm NGM DVD - I was very conscientiously running my Roundhouse Alco at a typical scale snail speed as he was videoing it close in.
I did try to select the best footage in that regards this year and I feel that we are slowly getting there!
Keith S
Post by Keith S » Thu Mar 23, 2017 1:20 am
The "momentum" vans and "Slomo" devices gaining popularity really make a difference in this regard.
For me it's all about steam. It's the difference between a convincing fake and a real train, as far as I'm concerned. You can glue little puffs of green-dyed foam rubber to a twig and call it a tree, if you like, or you can have a real tree. For me it's the same thing with the trains. The non-functioning scale details are all just gingerbread.
Post by LNR » Thu Mar 23, 2017 1:32 am
I totally agree with you Keith, even though I have glued pieces of green stuff on branches and called them trees. All scales have their pro's and cons and an objective for being. For me though, you can't beat real hot oily live steam, on the road, rails or water.
Killian Keane
Post by Killian Keane » Thu Mar 23, 2017 7:41 am
I share that sentiment also! I wouldn't have got into 16mm if it were all electrickery, steam is steam and nothing can imitate it
artfull dodger
Re: 16mm and its relationship with other scales
Post by artfull dodger » Sun Apr 16, 2017 7:43 pm
The sounds, smells/aroma that live steam brings to a garden railway is, to me what brings it alive. Roundhouse uses this in thier advertising as Living Steam Railways. Even standing still, a steam engine is alive with all kinds of sounds and smells. Even though most of us lack the aroma of a coal fire, the rest of the associated smells are there. And a piece of hard coal in the bottom of the smoke box, will give off some slight aroma without actually burning, and it will absorb some of the oil and gunk from the exhaust. If I manage to sell my two engines and down size to a RH Katie, I believe I will fit a Slomo to her and leave her manually controled. Only batteries being in the lantern on the front or rear of the engine. Cheers Mike
Keith S
Post by Keith S » Sat Apr 22, 2017 6:32 pm
As my father does very clever models in "HO" scale, I appreciate the trains and the modelling. But as for me personally, the only reason there is a train in my house is that it's a steam train. I enjoy steam powered equipment, and when it comes to "playing" with steam models, the train is the easiest, because it will follow some tracks and presumably look after itself, as opposed to boats and traction engines, which require active steering. And I like things that move, so even though I appreciate stationary engines, I don't tend to want to play with them.
However, now that I have a steam-driven train, I am starting to enjoy bolting details onto the locomotive and I like the colourful wagons and coaches. I even bought a semaphore signal kit at the AGM, so perhaps I am getting a little deeper into "model railways" than I had intended. No harm in making it all look convincing is there?
IrishPeter
Post by IrishPeter » Wed Aug 09, 2017 5:39 am
I have more honest enthusiasm for my Millie plodding along at something like a scale 15mph with three wagons, a coach, and brake van on the hook on the Skebawn and Castleknox Tramway than ever I had for any of my OO efforts. There is something very absorbing about the whole process of running live steam on a 15/16mm scale line - you don't just flick a switch and go. She has to be cleaned, oiled, fuelled and watered; lit and allowed to boil; then there is the ceremony of clearing the cylinders of condensate, and then you are ready to go. It is a lot more total immersion than the smaller scales. Then at the end of the run, you have to put up locomotive, or refuel, etc., for the next run.
There is also the element of experiment - the "how can I represent X, or get Y to do Z" side of things. Personally, I loathe electronics, so I will tinker about with weighted levers, bell cranks, rodding, and all the paraphernalia of old school manual signalling rather than use point/signal motors. Another 16mm guy will embrace the electronics and tell you how to get the proper bounce into a semaphore signal using such and such a piece of electrickery, and operate off his R/C unit. It is a trivial example, but it does represent the sort of healthy eccentricity that seems to be so much of the Garden Railway/16mm scene. I certainly find it a very satisfying way of 'playing with trains,' rather than merely 'playing trains.'
Peter in VA
Killian Keane
Post by Killian Keane » Thu Aug 10, 2017 8:06 pm
Interesting to note that a typical 16mm wagon kit costs about the same as a 00 gauge wagon which costs the same as an n gauge wagon, as 16mm is 8 times the scale of n gauge, I rather fancy thats better value
Post by FWLR » Sat Aug 12, 2017 4:33 am
Being new to 16mm i can see what most members are saying about the smaller scales, however has i have said in my introduction to the forum, i have nothing against other gauges one bit, i see it has everyone is running trains however they run them, wether that is live steam, battery or mains. Every scale has it’s place in model rail, because even if you say garden rail is not modelling like the smaller scales or gauges however you want to portray the gauge, it is modelling, unless you can afford to run the original gauge ( you know like a Scotsman or similar ) we all model trains. I do love running my N Gauge 2mm scale layout, has i now can’t wait to run my 16mm/32mm locos, even if they are not live steam or resemble a steamer or diesel, the fascination for me is railways has a whole. I love steam of any ilk and while diesel doesn’t do a lot for me, i do appreciate the power they have, so yes i run them on my N Gauge.
But the main thing is, lets relax and enjoy the hobby, because that’s what it is really, a hobby, no matter how you run it. :thumbright: :thumbright:
listerboy
Post by listerboy » Tue Apr 24, 2018 2:25 pm
My experience at the weekend seems to reinforce my original post. As some of will know I was due to exhibit at the North Down Model Show in Bangor, N Ireland. I had booked 3 tables, which had disappeared prior to my attempted set up on Saturday morning. Some tables were acquired, but not enough to cover what I had requested, so I couldn't run trains.
I'm still waiting for a reply to my email to the show director.
Post by Big Jim » Tue Apr 24, 2018 2:42 pm
I would be interested to hear what their response is.
Perhaps it is more to do with bad organisation rather than a perceived snobbishness, although I do think this happens occasionally.
An example of snobbiness was seen many years ago when I was involved with the Brambleton Exhibition. We had a chap exhibit a wonderful Thomas layout one year, quite a size and very well detailed with some highly skilled modelling evident. The younger visitors (future of the hobby) and many adults thought it was great. This did not stop disparaging comments from some adults who seemed to feel that it was a OO scale aberration and sin against nature. One caught me at just the wrong moment to complain and got the hair dryer treatment.
While not a running layout, your display did look good though. Better luck next year.
listerboy
Post by listerboy » Tue Apr 24, 2018 4:39 pm
Thanks Big Jim! Although to be honest my faith in exhibiting there has taken a hit. I wouldn't have a problem with a Thomas layout like you describe, if it interests the children, possibly even an adult, it can't be a bad thing.
I will hopefully be exhibiting at the Cultra model railway day in November. I've always liked that as I should be surrounded by Donegal Railway vehicles!
Tingewickmax
Post by Tingewickmax » Tue Apr 24, 2018 5:41 pm
It seems in all of human endeavours that given a chance there will always be one or more who will cause a schism. Luckily I'm a member of a 16 mm group who have very wide ranging tastes - 32/45 mm gauges, 7/8"inch/15/16 mm/1:22.5/24 scales, prototypical/freelance, battery/gas/coal power, steam/electric/diesel/whimsical outline, manual/RC.........You get the picture, we just love running trains in the garden......and village halls and...... Somehow we all manage to rub along quite nicely. Well at least till I get my 1:20.3 3 cylinder Shay steamer out. Everybody hates that one as it goes round and round and round so s-l-o-w-l-y. Oh, and I do DC too on my line, Heretic ! :D
invicta280
Post by invicta280 » Tue Apr 24, 2018 9:31 pm
I have a 00 layout in the loft-or to be precise am in the process of rebuilding one. I am becoming increasingly fond of my old Hornby Dublo and Triang models which seem to have so much character and remind me of my youth. Also, they can be bought for reasonable prices on ebay. I have some modern Bachmann etc too but I now refuse to pay ridiculously inflated prices. I know they are more accurate to scale etc but the old stuff just seems so robust and the locos will pull anything. I'm not tempted by DCC ( or anything digital) and my old fashioned diesels emit a lovely growl so who needs soundcards?! It's only for fun anyway!
At heart I am an outdoor person, and my wife and myself love working in the garden, so with live steam as an added bonus it's not surprising that most of my effort currently goes into building a 16mm line. Currently got 10 metres of trackbed prepared for tracklaying, now for the straight section behind the pond.... :)
artfull dodger
Post by artfull dodger » Tue Apr 24, 2018 11:14 pm
We so need a "like" button on this forum. Several posts needed one! I have owned several different live steamers, from several major brands including a couple gauge 1 Aster engines. But I have gotten the most enjoyment from the 2 engines I have now, an LGB/Aster Frank S to go with my LGB narrow gauge European wagons and coaches, and my Roundhouse Bertie that I sold and regretted, and then just bought back. Sometimes the simple engines are the most fun. Heck, lot of guys/gals have lot of fun with Mamod/MSS engines despite thier short comings. While I long to do 32mm gauge, my choice in engines are not regaugeable, and most every line I run on is 45mm as that track is the easiest to come by in the USA. But just like any other scale or hobby, just have fun and not let others dictate how you enjoy your hobby. Every hobby has its snobs, be it model trains or my antique garden tractors. And I have told off guys in both hobbys. If they do not like it, move on as your comments are not welcome. Rule number 1, its my railway/tractor, rule 2, if in doubt, refer back to rule number 1! Mike the Aspie
Post by Peter Butler » Tue Apr 24, 2018 11:43 pm
artfull dodger wrote: Tue Apr 24, 2018 11:14 pm We so need a "like" button on this forum.
NO...NO...NO... never! We need sensible communication and response to posts, not the simplicity to say 'like'..... that is the end of conversation!
