running Caradoc
pauly
running Caradoc
Post by pauly » Thu Feb 19, 2009 7:53 pm
I have finally got the courage up to run caradoc on blocks for the first time!
It was quite a challenge getting the fire to burn in th boiler and not in the smokebox but I got it right in the end
she is very stiff and clunkey at the moment
but will improve with running in
the burner was a lot quieter than I imagined and I can see the appeal of these locos :)
all in all shes a goodun
she will need a lot more running in on blocks before she ventures out into the garden but like children these little engines have to crawl before they can walk and walk before they can run. :)
A steam propelled life-style.
ACLR
Post by ACLR » Thu Feb 19, 2009 8:16 pm
looks good Pauly :D
andysleigh
Post by andysleigh » Thu Feb 19, 2009 9:05 pm
hallelujah!
Good to see your running it.
If you ever re place the chuff pipe, send the old one this way :D :P :happy3:
Re: running Caradoc
Post by MDLR » Thu Feb 19, 2009 10:24 pm
pauly wrote:she is very stiff and clunkey at the moment but will improve with running in
You will also find she'll run much more smoothly when she's on some track. I don't know why this should be, but it's certainly true!
MTA
Post by MTA » Fri Feb 20, 2009 10:26 am
Pauly,
My Roundhouse-Beck 'Anna' when first lit up tended to burn in the smokebox rather than the boiler. All I did was to turn the gas down until the gas was sucked into the flue with that satisfying 'pop'.
I'm pretty certain that applies to most locos :?
pauly
Post by pauly » Fri Feb 20, 2009 12:26 pm
so did I but it doenst POP back into the smoke box it just sort of quietly retreats :?
andysleigh
Post by andysleigh » Fri Feb 20, 2009 2:39 pm
somebody told me that before lighting, turn the gas on and leave it on for 8 seconds, this then clears the liquid gas and makes it easier to light.
pauly
Post by pauly » Fri Feb 20, 2009 9:08 pm
urr is there still an ;Edrig group; on this forum? Iv heard I can join with my caradoc?
andysleigh
Post by andysleigh » Fri Feb 20, 2009 9:23 pm
pauly wrote:urr is there still an ;Edrig group; on this forum?  Iv heard I can join with my caradoc?
there is, but Caradoc aint no Edrig ;)
pauly
Post by pauly » Fri Feb 20, 2009 10:03 pm
well Sillybilly posted this
Anyone who wants to join the 'Edrig Club' basically if you've got a Edrig, Caradoc or Mortimer, then pop andysleigh a PM and he'll add you to the group, it's viewable here www.gardenrails.myfreeforum.org/groupcp.php .
Doesn't make a difference to your 'status', if there is demand for further groups e.g. Mamod, then start a new topic in forum improvments!
SillyBilly
Post by SillyBilly » Fri Feb 20, 2009 10:36 pm
I did indeed and it still applies.
TonyW
Post by TonyW » Mon Feb 23, 2009 1:02 pm
Running on blocks does not fully "run in" the loco. As the wheels are spinning in mid-air there is no weight on the axles and their bearings, so not much running-in happens with them! Best to run it on track (or a rolling road), as already suggested.
