Adding revolving spectacle plates
John57sharp
Hi all, can anybody advise me how to remove the spectacle plates on an Accucraft Caradoc? I want to fit the Swift Sixreen revolving ones, but can't see how to take the old ones off without damage.
Cheers in advance.
John
Cheers in advance.
John
- Boustrophedon
- Chris Cairns
John57sharp
- Keith S
Be sure to post a picture when you are done. I fitted these spectacle plates to a RH "Billy" recently and they look great. BUT I had trouble soldering them. The outside ones turned out OK but I ended up gluing the inner ones because the outer ones kept coming off with the heat when I tried to solder the inside ones. No doubt due to my lack of soldering skill. But they look fine.
