Wild Rose ~ Quarry Hunslet
Re: Wild Rose ~ Quarry Hunslet
Interesting photo Dave. I assume the stuff fixed to the top of the Face plate is to balance the load. Novel way to power your lathe. Presumably with a small lathe it is a case of light cuts to not overload it.
Don
Don
Thats even more impressive Dave. That little lathe has done a brilliant job for you, with your help of course....
Seriously though. That shows how good an engineer you are, wether you are qualified or not....
- dewintondave
That's it, Don, it's counterbalancing. It was a successful way to power the lathe with more power - 1/4 hp good speed range and none of the intermittent running that the original motor needed.
Thank you, Rod!
As LBSC would say, the loco is on the Erecting Bench!
Some painting has been done with spray can and brush - some old enamel from years ago that now takes an age to dry.
I'm assembling the loco with oil blackened roundhead 8BA screws. Today I oil blackened the chimney so that I wouldn't have to paint it. The finish is pleasing, and the distortion from heating has caused it to fit better
Best wishes,
Dave
Dave
That looks great, chemically blackening shows off rivet detail and plate work far more crisper than when items are painted.
Stunning work Dazza. Everthing is so neat and precise. As Tom says the oil blackening has worked really well.
Don
Don
- dewintondave
Finally got the big loco plumbed-in, water and steam leaks sealed, and semi painted. When I saw how clean and nice the smokebox interior was while building I knew I wouldn't coal fire it, so it's gas-fired It needs the suction fan for lighting, and steam blower to keep the fire going in the right direction. The big cylinders need their draincocks
Here we are water pump testing, and successfully pumping water into the boiler
Best wishes,
Dave
Dave
Sorry for the late reply Dave. Not been to good just lately. Love this little loco mate, the whistle is a joy to hear. Wish you lived nearer to me, then I could possibly see it in the flesh so to speak and wonder at the workmanship you put into your loco's...
- dewintondave
Thank you Rod. I hope you are doing better now. I'm beavering away on the buffers and couplings at the moment
Best wishes,
Dave
Dave
Hi Dave,
I've just re-read your build thread, and as everyone has said it's a beautiful job. Could you explain the plumbing of the cylinders please? I understand they are double acting and reversible, but how do you keep the exhaust going up the chimney? My tiny brain has tried and failed to work it out. I ask because I have an idea for my first attempt at scratch building a loco with oscillating cylinders.
Best,
Tom
Best,
Tom
- dewintondave
Thanks, Tom!
I hope this picture helps There's the rotary reversing valve which is fed by the steam pipe from the boiler and discharges into the exhaust pipe that goes up the chimney. There are two pipes on each side of the rotary valve feeding to the cylinder port blocks. Each port block has two long drillings that supply the two port holes at each end of the port block. Either top or bottom ports can be steam or exhaust. Looking at the side pipes coming from the rotary valve, the valve connects one of the two sets of pipes to the steam supply and the other to the exhaust. When the lever is moved the other way the steam and exhaust connections are reversed. The steam has to move the pistons before it can travel to exhaust. The valve body has 4 holes, 1 for the steam, 1 for the exhaust, these are the horizontal holes. Then the upper and lower holes are for the pipes to the cylinders. The curved grooves in the rotary part connect the exhaust and steam to alternate cylinder pipes
Best wishes,
Dave
Dave
Ah ha, thanks Dave I see it now. It's a such simple and elegant way of doing it, and didn't Mr Kalashnikov say "simplicity is underrated", or words to that effect. You have inspired me to have a go!
Best,
Tom
Best,
Tom
- dewintondave
I'm a big fan of this picture showing how Mamod did it Tom, it's lovely engineering
Best wishes,
Dave
Dave
Hi Dave,
Sorry to barrage you with more questions. How are the pipes between the rotary valve and the port blocks fitted? Are they a fit, silver soldered or threaded and o ringed in some way?
Best,
Tom
Best,
Tom
- dewintondave
It's fine Tom, it's been really quiet lately. That was the tricky bit, the pipes screw out from the valve housing and are sealed at the port blocks by O-rings
Best wishes,
Dave
Dave
Hi Dave,
Thank you so much for those pics, I'm so glad I asked, that's a sweetly engineered solution. I would never have guessed the details from your other pictures.
I bet they were fiddly to make too, is that 3 parts per pipe, or is the abutment turned as part of the pipe? Also, what's the reason for using two different sizes of O ring if both ports can be either inlet or exhaust?
Best,
Tom
Best,
Tom
- dewintondave
Thanks Tom!
I'm doing the buffers at the moment, copying the large De Winton's arrangement
Best wishes,
Dave
Dave
- dewintondave
Thanks Tom, it's a bit of copy of what Aster did on my Baldwin, except theirs don't screw out.Tom the blacksmith wrote: ↑Mon Oct 28, 2019 7:48 pm Hi Dave,
Best,
Tom
The pipes are one piece, with a nut glued on to help with the screwing out into position.
The pipes are different sizes 1/8" for steam and 5/32" for exhaust when running forwards. We'll see if it makes any difference, it was to ease the flow of exhaust.
Best wishes,
Dave
Dave
Hi Dave,dewintondave wrote: ↑Tue Oct 29, 2019 7:06 am The pipes are different sizes 1/8" for steam and 5/32" for exhaust when running forwards. We'll see if it makes any difference, it was to ease the flow of exhaust.
I thought that might be the case, as well as easing exhaust out you might be keeping inlet gas speeds high for good cylinder filling. I would be intrigued to hear what you find, please keep us posted. Love the buffers too!!
Best,
Tom
Ps that wood looks a little like purple heart?
- dewintondave
It's Kwila Tom, it was rock hard so I milled it in the lathe
Best wishes,
Dave
Dave
