Llewellyn Loco Works #1
Keith S
Re: Llewellyn Loco Works #1
Post by Keith S » Tue Apr 13, 2021 12:27 am
I always look forward to progress updates on this locomotive. I think it's a fascinating project, with many refinements not seen on commercially-available models. It's gratifying to follow along with projects like these.
stesc
New User
New User
Post by stesc » Thu Apr 22, 2021 4:35 am
Hi
love your work - what tooling are you using for the threading - it looks like HSS insert
Hydrostatic Dazza
Post by Hydrostatic Dazza » Thu Apr 22, 2021 8:55 pm
stesc wrote: Thu Apr 22, 2021 4:35 am Hi
The tool is a Japanese made Kyocera TTX and the inserts are their PVD Coated Carbide tips from the TTX32R range and so far I am very pleased with the set up. I am not a fan of inserts for ME work but for fine thread accuracy, for my main turning I use Coblat in the Eccentric tool holders and I am very pleased with these.
Hydrostatic Dazza
Post by Hydrostatic Dazza » Tue Aug 10, 2021 10:29 pm
For those who are bored
update pics of the loco build here, close to cooking up the cab and tank plate work. The water tank is done. Not long till I plumb it all up. Might be able to test steam early 2022 at the current rate.
https://www.flickr.com/photos/llewellyn ... 1626418076
Not a lot of further progress on the "Potters Orchid Railway"
https://www.flickr.com/photos/llewellyn ... 4810620477
Meanwhile my full size driving at the Mary Valley Rattler progresses and I have have become a C1 driver/tutor.
https://www.flickr.com/photos/llewellyn ... 1403229215
Nickclarke
Post by Nickclarke » Sat Aug 21, 2021 11:39 pm
Your workmanship is exquisite!
Hydrostatic Dazza
Post by Hydrostatic Dazza » Tue Aug 24, 2021 12:05 am
Nickclarke wrote: Sat Aug 21, 2021 11:39 pm Your workmanship is exquisite!
Thankyou. However I am yet to complete one working loco and yet to prove it in steam.
Maybe next year it will steam.
Hydrostatic Dazza
Post by Hydrostatic Dazza » Wed Aug 25, 2021 3:57 am
I have been doing jobs in the Red Room around my work and also my driving/firing stints at the Mary Valley Rattler. Currently I am making the tank filler lids for the 16mm loco.
ImageIMG_6256 by Darrell McCulloch, on Flickr
ImageIMG_6262 by Darrell McCulloch, on Flickr
ImageIMG_6265 by Darrell McCulloch, on Flickr
ImageImageIMG_6267 by Darrell McCulloch, on Flickr
ImageIMG_6299 by Darrell McCulloch, on Flickr
Hydrostatic Dazza
Post by Hydrostatic Dazza » Wed Aug 25, 2021 3:59 am
2.50 and 2.00 silver steel buttons full hardened, file and sand. I have rehearsed this before when I did the one for the tender.
ImageIMG_6300 by Darrell McCulloch, on Flickr
ImageIMG_6306 by Darrell McCulloch, on Flickr[/img]
ImageIMG_6307 by Darrell McCulloch, on Flickr
ImageIMG_6309 by Darrell McCulloch, on Flickr
Hydrostatic Dazza
Post by Hydrostatic Dazza » Wed Aug 25, 2021 4:04 am
Fixture to hold all square for tacking. Cooked up with 243 Soft Solder. It fits. The idea is it all can be removed via 4 bolts and everything stays undisturbed for testing and also for maintenance and cleaning. Well that is the theory at this time.
ImageIMG_6278 by Darrell McCulloch, on Flickr
ImageIMG_6285 by Darrell McCulloch, on Flickr
ImageIMG_6292 by Darrell McCulloch, on Flickr
ImageIMG_6293 by Darrell McCulloch, on Flickr
ImageIMG_6295 by Darrell McCulloch, on Flickr
ImageIMG_6296 by Darrell McCulloch, on Flickr
Hydrostatic Dazza
Post by Hydrostatic Dazza » Wed Aug 25, 2021 4:39 am
ImageIMG_5980 by Darrell McCulloch, on Flickr
ImageIMG_5975 by Darrell McCulloch, on Flickr
ImageIMG_5963 by Darrell McCulloch, on Flickr
ImageIMG_5978 by Darrell McCulloch, on Flickr[/img]
Post by ge_rik » Wed Aug 25, 2021 11:49 am
Once more, your attention to detail and engineering capabilities astound me. I'd struggle to produce any one of the items on your loco. Have you worked out how many separate parts have gone into it so far?
Hydrostatic Dazza
Post by Hydrostatic Dazza » Wed Aug 25, 2021 9:37 pm
ge_rik wrote: Wed Aug 25, 2021 11:49 am Once more, your attention to detail and engineering capabilities astound me. I'd struggle to produce any one of the items on your loco. Have you worked out how many separate parts have gone into it so far?
Thanks, no idea of the part number, I can check with the CAD program the number of part files, it may miss duplicates I have not repeated in the model.
This project grew in complexity by a factor of 10 as it progresses. It was started as Brian Wilson's Eric design but after the valve gear geometry fix and then coal firing and then Slomo and onwards. It is teaching me a lot about this sort of design and metal work, after this I am onto a 5" gauge loco. Along with mucking about in the garden gauges and the Potters Orchid Railway.
Post by FWLR » Fri Aug 27, 2021 7:57 am
Going to be another fine looking loco from you mate. :thumbright:
Hydrostatic Dazza
Post by Hydrostatic Dazza » Fri Aug 27, 2021 10:36 pm
FWLR wrote: Fri Aug 27, 2021 7:57 am Going to be another fine looking loco from you mate. :thumbright:
Thanks. However it will not be another loco. This will be first one I hope to finish within the next 12 months.
Hydrostatic Dazza
Post by Hydrostatic Dazza » Fri Aug 27, 2021 10:40 pm
Solder paste, my second only time I have used it. Worked OK.
ImageIMG_6317 by Darrell McCulloch, on Flickr
ImageIMG_6319 by Darrell McCulloch, on Flickr
bambuko
Post by bambuko » Sat Aug 28, 2021 1:03 pm
Hydrostatic Dazza wrote: Fri Aug 27, 2021 10:40 pm Solder paste...
silver solder paste? or some other solder paste?
thank you :thumbright:
Hydrostatic Dazza
Post by Hydrostatic Dazza » Sat Aug 28, 2021 9:46 pm
bambuko wrote: Sat Aug 28, 2021 1:03 pm
Soft solder paste in a tube, bought from Jacar electrics.
Jimmyb
Post by Jimmyb » Sun Aug 29, 2021 5:19 pm
Not seen sliver solder as a paste!
bambuko
Post by bambuko » Sun Aug 29, 2021 6:07 pm
Jimmyb wrote: Sun Aug 29, 2021 5:19 pm...Not seen sliver solder as a paste!
Just one example (many more out there...)
https://www.cooksongold.com/Solders/Sil ... escription
Jimmyb
Post by Jimmyb » Mon Aug 30, 2021 8:08 am
bambuko wrote: Sun Aug 29, 2021 6:07 pm
Many thanks for that, very interesting :)
