-TOP SECRET-
Dr. Bond of the DVLR
Post by Dr. Bond of the DVLR » Tue Jan 18, 2011 8:54 pm
Today I designed the chassis for the wagons, bit tricky as there is a second floor with inset for a hinge, plus places for all the braking bits to go...
Post by Dr. Bond of the DVLR » Wed Feb 02, 2011 6:24 pm
Been also making lots of little malt sacks to go in them. About 2/3 will be full 1/3 will be empty. Each is made of linen that looks like hesian, was LASER cut out and stuck together with Copydex. Then I made a LASER cut /engraved stamp out of ply wood and using an ink pad the words "SNAPE MALTING'S FINEST BY RAIL DVLR is printed onto each, you can't read all the words on each sack but that adds to the ageing of them. Then each on to be filled is filled with rice and the top is then sewn up to give a "draw string" look to it and tied off. The top is cut off and everything is neatened up and voila!
One sack. I've got 150 to make and this is how far I've got:
:shock:
Post by Narrow Minded » Wed Feb 02, 2011 6:37 pm
I bet those long winter evenings just fly by!! :D
Seriously though Mr. B. those look excellent!!
taliesin001
Post by taliesin001 » Wed Feb 02, 2011 6:47 pm
very realistic, a nice job!
Post by 90733 » Wed Feb 02, 2011 6:56 pm
Ar, those dreaded sacks!
Very good buy the way, look very real, the stamp works well.
Thanks
Jack
Sir Clothem Cap
Post by Sir Clothem Cap » Wed Feb 02, 2011 10:50 pm
excellent attention to detail there Mr Bond
Post by Dr. Bond of the DVLR » Sat Feb 19, 2011 9:49 pm
You see all the little circles on the sides? Well they are slowly being covered by little plastic dots in an activity I can only describe as [sarcasm] riveting [sarcasm/]
Post by Dr. Bond of the DVLR » Sun Feb 20, 2011 9:55 pm
Riveting is done on two of the three. Now onto painting!
taliesin001
Post by taliesin001 » Sun Feb 20, 2011 10:21 pm
Looking good Mr bond! Don't envy you with those rivets, lucky I only have to do a few!
Post by Dr. Bond of the DVLR » Mon Mar 14, 2011 8:16 pm
Trying to buy some wheels and axle boxes for these. To fit the three wagons with wheels and axle boxes from IP as I normally do is now 27 pounds! I might go for AnDel wheels with Cambrian axle boxes but then you loose the lovely clickety clack of the wheels on the rails. They will look nicer however... What should I do???
Oh pics of the wagons progress to follow...
taliesin001
Post by taliesin001 » Mon Mar 14, 2011 8:34 pm
As your entering into the competition I would go for the andel wheels and cambrian axelboxes because as you say they look better and looks is everything! :D
Post by Dr. Bond of the DVLR » Wed Mar 16, 2011 10:23 pm
Right, heres how the painting is going:
OFcource muggins here didn't paint the raised up bits before gluing them on so it takes me 2 hours per wagon to paint on all the black with a brush!
Post by Dr. Bond of the DVLR » Thu Mar 31, 2011 10:20 pm
rather a long time since update, I'll explain later - busy painting them!!!
Post by Narrow Minded » Thu Mar 31, 2011 10:30 pm
They look great Mr B. :D Makes for a lovely looking rake - and those knots are impressive ;)
One complaint - you can't see the interior roofing detail from the photo's. Having seen it in person I feel you should share it with the masses!
mhlr
Post by mhlr » Thu Mar 31, 2011 11:47 pm
Ay up lad those are very impressive! Can you get some 32mm wheelsets in for running here?! :lol:
METHSSNIFFER
Post by METHSSNIFFER » Thu Mar 31, 2011 11:55 pm
Are you saving the pop up giraffes for the show !! They look brilliant good work!
