or are you making it yourself as well
when I tried to source some, the smallest I could find in steel was M5 or M6
anything smaller was either plastic or aluminium...
To be honest I cannot remember now.
It should not be a problem, unless one thinks corrosion might be a problem , the aluminum encapsulates the bronze / brass bearing, the centre bearing is steel, could be even stainless ? I am sure it will be certainly strong enough.
SKGLB wrote: ↑Fri Apr 24, 2020 5:25 am The ball joints are still available from Knupfer, from 2 - 4 mm.
https://knupfer.info/shop/index.php/deu ... kopfe.html
Greetings from Austria
Gerald![]()
tom_tom_go wrote: ↑Sat May 02, 2020 9:09 am How are you going to go about fitting the Slomo into the tender?
Keith, yes I gather I will be giving this tender some extra weight in the spare pockets of space and checking the axle load is even. The Slomo is at this time resting on 3mm brass plate which is bolted to the tender sole plate, I intended to use some Bicycle inner tube between the Slomo mech frame and the tender mounting plates. Also some nylon washers under the M3 mounting screws for what that may help ? I am completely winging this build, I have never done this before, I am just reading and watching and trying to absorb as much as I can for this build. For example after reading an article in SMT mag I recently decided I am going to hook a servo to the blower, so when the loco is stopped one can keep the fire going. Crikey, I am yet to get my head around RC stuff. I am not a fan of electronics but I will endure for this project. This build is a tool and skill and knowledge acquisition process for the the next big project, the 5 " QR C17 #253 as delivered in 1921. Videos will be done, I reckon some time late next year I will be steam testing, all depends on the Rattler and how often I am in Gympie crewing the 12"to the foot locos. I am very much enjoying this project. I have a 5" 1/2 built loco but I have no interest in it at all. This is more fun. I am happy to hear it is all of interest to others.Keith S wrote: ↑Fri May 08, 2020 7:39 pm I don't know if you're already planning to do this, but the heavier you make that vehicle, the better it will work. I have two steel plates inside my "flywheel" van, about 3/4" thick and approximately 8"x3". I tried to weigh it for you, but it maxes out my kitchen scale and doesn't register on the bathroom scale. I thought about weighing myself with and without it, and subtracting the difference, but I am pretty dedicated to not knowing how much I weigh.
I'd guess it's about the same weight as a large tin of beans, or a pork loin roast. Maybe 1.5kg. This isn't a scientific measurement, I just went to the freezer and held the van in one hand and the pork loin roast in the other. Sorry.
I notice you've hung the slomo from rubber dampers between itself and the tender frame. Good idea! It should be nice and quiet.
Anyway other than that, I like the nice clean platework so far. I am really looking forward to seeing this loco finished. Hopefully you don't mind posting some video!
Yes, the innards of the Slomo mech are indeed isolated with rubber rings inside the outside Slomo frame. That was how it came. I misunderstood and thought you were referring to the plates between the Tender sole plate and the Slomo mech.
