P&J sheep and coal wagon
andysleigh
Post by andysleigh » Wed Dec 30, 2009 9:54 pm
Hancockshire wrote:For painting, use thinned down enamel paint to make it look old. Alternatively, you could paint it normally then get wet & dry paper around the edges of the wood.
thats kind fo what i was guna do.
spray it grey primer, rub, primer, rub a bit, top coat, rub, etc until the finish looks good.
use watered down black/ grey etc for weathering, for the outside.
not sure about the inside. Has to be a bit brown from all the sheep poo poo, dorty, worn.
Dr. Bond of the DVLR
Post by Dr. Bond of the DVLR » Wed Dec 30, 2009 10:07 pm
would the base planks have been painted?
I don't think so if they were just going to be trod and deficated upon by sheep!
andysleigh
Post by andysleigh » Wed Dec 30, 2009 10:09 pm
Mr. Bond of the DVLR wrote:would the base planks have been painted?
there wouldnt have been much point.
it would only wear off. you never really see the inside of wagons painted
Post by MDLR » Wed Dec 30, 2009 10:24 pm
Another thing you can try is VERY dilute Indian ink - makes new wood look old. I'll probably do that with the replacement bits for my sheep wagon, so it looks like it was repaired some time ago.
andysleigh
Post by andysleigh » Wed Dec 30, 2009 10:27 pm
MDLR wrote:Another thing you can try is VERY dilute Indian ink - makes new wood look old. I'll probably do that with the replacement bits for my sheep wagon, so it looks like it was repaired some time ago.
ah yes, i have heard about using Indian ink. though couldnt remebr very well.
Do you know of any pictures with any of it done?
Hancockshire
Post by Hancockshire » Wed Dec 30, 2009 10:50 pm
Sheep crap is dark brown with a bit of yellow(I know from experience)
andysleigh
Post by andysleigh » Sat Jan 23, 2010 11:04 pm
Now painted the wagon in its colour. the outside, and inner sides need weathering, i shall probably have my heart in my mouth when doing it.
the floor is weathered.
Post by MDLR » Sat Jan 23, 2010 11:09 pm
I like that - particularly the fact that the weathering doesn't go all the way to the sides - looks like it's not been long in service.
mhlr
Post by mhlr » Sat Jan 23, 2010 11:14 pm
Yeah I also like the way the floor muck doesn't go to the sides... as sheep wouldn't put their feet there anyway.
MTA
Post by MTA » Sun Jan 24, 2010 9:59 am
Fandabydozy :D
Really looks the dogs parts. One thing, are you going to paint the strapping at some stage?
MoelygestLR
Post by MoelygestLR » Sun Jan 24, 2010 4:35 pm
MTA wrote:Fandabydozy :D
[offtopicness] Lee Evans? :lol: :) [/offtopicness]
andysleigh
Post by andysleigh » Sun Jan 24, 2010 4:56 pm
nope
may add a bit of rust etc.
Post by Dr. Bond of the DVLR » Sun Jan 24, 2010 8:20 pm
Looks brill andy!
I'd paint the strapping black but its your wagon!
Like the weathoring but what happened to all the sheep muck you promised?!!
andysleigh
Post by andysleigh » Mon Jan 25, 2010 3:33 am
i have worn, and weathered most of it now, i shall add some light rust colour to the metal bits.
The paint is special weathering paint from Phenix Percision,
worn wood, dirty black, and sooty deposits, which are perfect really.
Post by Dr. Bond of the DVLR » Mon Jan 25, 2010 8:31 am
Brilliant, do pheonix make a paint called "Sheep poo" ?
andysleigh
Post by andysleigh » Mon Jan 25, 2010 3:02 pm
Mr. Bond of the DVLR wrote:Brilliant, do pheonix make a paint called "Sheep poo" ?
funnily enough, i dont think so!
could always get the real stuf, and water it down......
mhlr
Post by mhlr » Mon Jan 25, 2010 7:57 pm
andysleigh wrote: could always get the real stuf, and water it down......
Just peel it off the underside of my quad bike if you come down mate ;) :lol:
METHSSNIFFER
Post by METHSSNIFFER » Fri Sep 27, 2013 1:51 am
Are these kits still available
andysleigh
Post by andysleigh » Fri Sep 27, 2013 1:56 am
as far as i know they arent.
P&J was bought by IP Engineering, but they havnt brought them out.
might be worth dropping them an email.
METHSSNIFFER
Post by METHSSNIFFER » Fri Sep 27, 2013 1:58 am
I will thanks Andy
