Smallbrook kits
Crackingjob
Post by Crackingjob » Thu Jan 23, 2014 12:15 pm
The man to track down is Chipping Clinker on the Gn15 site and AWNUTS site...suggest you join the Gn15 site they are very helpful.
Here is an example of his work as seen on AWNUTS
http://whymsical.com/index.php?topic=87 ... 88#msg7188
Droopy
Post by Droopy » Sun Feb 02, 2014 9:07 am
Thanks.
I found this answer from Smallbrook for 250mm radius curves:
"With regards to the small track radius, it should be OK.
The only thing is that the overhang at the end of the loco is a little more with Katie and Pierrot than Columbine and Harlequin.
If you can make your own track, so much the better, as with flexible track the gauge narrows on bending it into a curve but if you make your own
you can increase the gauge slightly on the bends and this makes life easier for the locos and stock."
Hope this helps. :D
kandnwlr
Post by kandnwlr » Wed Mar 05, 2014 8:39 pm
Droopy:95391 wrote:Got it !
They´re great kits!
