funandtrains:94513 wrote:I was wondering if rather than trying to design big boiler from scratch and hope that it steams well why not consider using a proven small 3 1/2 inch gauge loco boiler design such as a Titch or Rob Roy.
There is plenty of information around for designing boilers from scratch and existing designs are easy enough to modify if you stick to the rules.
Except for Tich, most 3 1/2" gauge boilers would be physically too large for SM32/45 locos., but some 2 1/2" gauge boilers would be in the right size range. You would still have to run through the calculations to check the boiler would steam the size of cylinders you wished to use.
As it happens I had a look at the small Tich boiler drawings a while back to see if it was useable in this scale. It was an academic exercise, as I've no interest in coal firing in this scale.
The small Tich boiler has the capacity to easily steam four Roundhouse cylinders, if you wanted to build a coal fired Garratt about the size of K1 using a couple of Roundhouse Katie chassis. It's the right diameter, but actually a bit shorter than scale for K1, but that's not a major problem. The fire tubes are of a size that would still steam OK if the boiler was made 1 1/4" longer. The firebox may also need to be made a bit shallower so the ashpan will clear the rails.
