Post
by tom_tom_go » Sun Feb 15, 2015 4:51 pm
I think I am about done with this wagon. I wanted to fit a hand brake, however, the axle boxes stick out too far and catch the arm on the brake lever:
Colour wise, going to go for all black weathered look and add PW markings as it looks good carrying track ballast.
I will be using Plastikard more on my future projects, great stuff!
Post
by philipy » Sun Feb 15, 2015 7:10 pm
That looks fine. Good job well done.
Post
by Peter Butler » Sun Feb 15, 2015 10:11 pm
I've been promoting the use of Plasticard for some time now so I'm delighted to hear from another convert how useful a material it is!
Nice job on the wagon...... more please!
Post
by tom_tom_go » Sun Mar 15, 2015 10:34 am
Post
by Soar Valley Light » Sun Mar 15, 2015 4:57 pm
Absolutely superb!
KNO3
Post
by KNO3 » Sun Mar 15, 2015 11:27 pm
Very nice!
Where did you source the wheels and axleboxes, and the couplers?
robc_wa
Post
by robc_wa » Mon Mar 16, 2015 4:16 am
Looks really good! I tried plastic angle as corner plates but the stuff I was using had a greater than 90 degree angle on the inside which was not good. What brand did you use?
Rob
McRuss
Post
by McRuss » Mon Mar 16, 2015 11:46 am
Hello Tom,
what dimension did the wood strips have?
And could you maybe made a drawing and a
material list for these wagon?
yours
Markus
Post
by tom_tom_go » Mon Mar 16, 2015 4:09 pm
Hi,
The axleboxes are Accucraft L&B with Plastikard added for the leaf springs.
The price has increased since I purchased these a while back (£7.50 from TrackShack now) so I would go for the IP IoM offerings which will look good at £6.50 with the springs as part of the casting. They also include brass bearings.
The wheels are again Auccraft L&B 25mm, 32mm gauge
Rob, the plastic angle is from a DIY store here in the UK called B&Q. You could try metal angle instead which should not have any deformities.
And (yes you guessed it), the choppers are also Accucraft. They are shortened although I am still trying to perfect this process and keep makng mistakes ruining the coupler housing on some sets (very annoying and costly). My next attempt at one will be with a mini hacksaw with the coupler housing bolted onto a plank of wood which I can then clamp in my vice. This should allow more accucrate cutting (hopefully).
The safety hook/chains is from BrandBright and fixed under the chopper.
If more people are interested I can do some measurements and a drawing although it might take me a couple of weeks to fit in round work/family life.
Paul_A_C
Post
by Paul_A_C » Sun Sep 16, 2018 9:39 pm
Tom,
The iron work on the sole bar in front of the W irons, I.e the 2 vertical straps and the inverted ‘horseshoe’; where did you source those from?
Post
by tom_tom_go » Sun Sep 16, 2018 9:59 pm
Paul_A_C wrote: Sun Sep 16, 2018 9:39 pm
Tom,
These are white metal castings from IP Engineering:
http://www.ipengineering.co.uk/page94.html
The price has gone up since I bought some, does anyone else supply these maybe using plastic instead to reduce cost?
Paul_A_C
Post
by Paul_A_C » Sun Sep 16, 2018 10:46 pm
Thanks, a tad pricey, but they would save a fair amount of time.
and1n
Post
by and1n » Tue Oct 01, 2019 4:13 pm
Hi
I would be interested. I'm new to 16mm/SM32. I'm moving up a scale from Gn15 and I've yet to get my head around this larger scale.
Thanks
Andi
Andi N
