My Garden Railway .. so far
Sammmm
RWeb
- Dr. Bond of the DVLR
- Retired Director
I shouldn't worry about down sizing gardens! In my old garden I had a scale mile or so of gauge one track. Now look what I have- a glorified shelf in a postage stamp garden that I am not allowed to extend yet
I think that smaller railways have the potential for greater detail and atmosphere although someone's bound to correct me on this!!!
Sammmm
- Retired Director
SillyBilly
Sammmm
Sammmm
Well i experimented with a mix
1 Part cement
4 1/2 part sharp sand
1 part compost (with large bits removed)
Water to a mortar consistancy maybe a little wetter ( but not too wet ! )
Then i use disposable plastic gloves to apply it to the track patting it to get it to move into every bit (when you patt it it will apear to gett wettter dont worry )
then using a Mid soft brush ( i use a brush off a dustpan and brush ) and brush it until you can see sleepers and making sure edges of rails are clear for flanges
1 Part cement
Thanks for that. Sounds like a variation on the good old "Rowlands Mix" - exactly what I intend doing actually
I'm fed up with trying to get gravel that looks anything like true to scale (especially in photo's - it's not too bad using the 2 metre rule) that the Blackbirds and Dunnocks don't throw all over the place!
Should be nice and easy to clear for a running session for us ground level line gang too
Sammmm
Umm at some point probly put a halt but after the plants have matured so i can see where to put it and where to put more plantsMr. Bond of the DVLR wrote:Looks brilliant, what are you going to do with that back bed which the railway runs through?
Top Tip for cat deterrent:- save some old teabags and let 'em dry out. Meanwhile get a small bottle of "Olbas Oil" and then put several drops on each of the teabags.
Place the Olbas soaked teabags in the cat sensitive areas and they should stay away.
It works for me with our cat and the neighbours felines which invade the garden and it's a cheap and easy solution to try
Sammmm
Right long due update!!!! although no pictures of the construction of the railway...yet... but more of general ones and some irrelevant but interesting pics and a video... will update on how the line looks in the coming weeks.
Firstly
Edrig lights up whilst the baguely has fun.
Pressure building!
View from firemans side window.
Snow now!
*irrelevant*but was down my girlfriends Stables and removed this from a bucket it january!
now a very odd picture from a bonfire a few days before haloween in wales...fire looks like a demon!
And back in the summer had a trip on this beastie! will post vids in coming weeks...(VEY LATE
BUT IM LAZY)
Ohh and the extent of the melting point dilema.....mentioned in another post.
Finaly the video which is recent!and ran behind Falcon from the Compton Down Railway
<object width="480" height="390"><param name="movie" value="http://www.youtube.com/v/oZECkYW3_Gw?fs ... ram><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/oZECkYW3_Gw?fs=1&hl=en_GB" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="390"></embed></object>
Firstly
Pressure building!
Snow now!
