Llewellyn Loco Works #1
Hydrostatic Dazza
Re: Llewellyn Loco Works #1
Post by Hydrostatic Dazza » Thu Mar 01, 2018 9:10 pm
I needed some tough spanners that can be heaved about for the bigger jobs in the workshop and take some abuse, such as a good smashing with the flogging hammer. These hitch hiked to down under by Airmail (5 weeks)
Hydrostatic Dazza
Post by Hydrostatic Dazza » Sat Mar 03, 2018 9:17 pm
Swinging off the big spanners
Lots of complication for the method of the expansion link making, ponder, sketch .........................
dewintondave
Post by dewintondave » Sun Mar 04, 2018 6:57 am
Lovely work Darrel!
I'm going to be making similar drain cocks for my oscillating cylinders. My engine runs wet and seemed to be getting water trapped right at the ends of the cylinders when the ports were closed. I've got a cylinder on the vertical slide right now.
Best wishes,
Dave
Post by tom_tom_go » Sun Mar 04, 2018 8:17 am
Agree with Dave, completely in awe.
I would love to have the ability and equipment to make similar drains for Roundhouse cylinders.
Hydrostatic Dazza
Post by Hydrostatic Dazza » Sun Mar 04, 2018 10:14 pm
I wanted to remove the need for brass shim in the expansion link fabrications as per the words and Music by Brian Wilson, so I mounted some annealed steel to a base on a rotary table and set about making three pieces into one piece. A mill here and a mill here and there............... The extra work involved is OK by me and it is all good education for the bigger and more complicated links that I intended to be making in the years to come.
It will all make sense later, but this is a stick with two small parts in it.
Plot the co-ordinates for drilling the expansion links, two on the piece of 1.60mm gauge plate, all from a common radius point
" Listen up you sods, this is how we will do it, no stuff ups OK ! "
In go the .50mm corner holes using the $2.00 Carbide PCB drill in a collet.
This is the way I am approaching the expansion links based on Brian Wilson's book. However my eccentric rod pin back set is in a different location as I have modified the valve gear geo. I wonder if it will work? The proving day gets a bit closer.
Knock off time on a hot and humid evening while listening to the Test Cricket from South Africa. The Aussies are heading for a win, but I would not get too confident, it was one destructive bowling session by Starck that did it, our batting is still iffy.
Hydrostatic Dazza
Post by Hydrostatic Dazza » Thu Mar 08, 2018 8:38 pm
The Tender Slomo mech arrives from "Small Steam Performance"and the staff gather around to have a gander at it.
Then it was back to work on the expansion links, one 3mm end mill became a casualty but all is going to plan.
Hydrostatic Dazza
Post by Hydrostatic Dazza » Sun Mar 11, 2018 8:55 pm
The staff at the Llewellyn Loco works have been busy, as always. The design for a new wet leg boiler is underway at the drawing office. Inspired by an article in "Australian Model Engineer" magazine.
Then there was Saturday at the Ipswich Heritage Railway Workshops and Museum for an "Association of Rail Tourism Queensland" meeting and this always involves a stroll through the workshops at the end of the day. I also volunteer here when I get the chance. I assisted in a very small way with the cosmetic restoration on the Hunslet that served on the Western Front before it came down under and slaved away on the sugar cane lines in Queensland.
The DD17 tank loco progresses with its new all welded steel boiler.
C17 #974 and the BB181/4 1079 and 1089 (Which is Australia's Evening Star). I hope to have some time firing on the #974 when it goes into service at the Maryvalley Rattler, fingers crossed.
One of the 2000 class railmotors.
Home on Saturday night after a good and eventful day out, I show MAM the head light I made for the little Greenblat loco kit she got me for Christmas and later while consuming home made Fish and Chips (Salmon = yum) and a glass or two of Red, MAM comments "where is the tail light, you are making a taillight for it !" "Aghhhhhhhhhhhhhh, yes, yes, you are right, it has to be done" . Sunday morning I get up, cup of tea, I rummage through what I have, LEDs, wires, connectors, switches and a Pendle Valley Tail lamp kit. I ponder all of this. I am an ignoramus with electrics but for the basics. I get in a right muddle. About 6 hours later, I have some thing that works.
I think it needs a little awning over the cab to keep the tropical sun off Mr Starboard.
Now what has this got to do with steam locos ????
It is intended that Llewellyn Loco Works #1 will have working head light and taillight on the tender as night time running is one of the reasons to live. So all of this is a good training and education excercise in LEDs, diodes and soldering for a proper or at least a better job to be done on the steamer. (with better and smaller connectors)
The Greenblat will be painted Safety Yellow as it will the POR's PR inspection trolley for running the road etc .
Later on Sunday Evening the expansion links are progressing while listening to the Test Cricket. The tricky milling is done. Now the next stages of cutting and fabrication begins.
While the mills was buzzing, MAM was ordering detail parts from the UK for her Lady Ann, inspired by an article in SMT mag.
Last edited by Hydrostatic Dazza on Sun Mar 11, 2018 9:30 pm, edited 1 time in total.
Post by tom_tom_go » Sun Mar 11, 2018 9:06 pm
Thanks for the pics.
I like the look of this loco:
Hydrostatic Dazza
Post by Hydrostatic Dazza » Sun Mar 11, 2018 9:34 pm
your desire can be sated
soon
https://www.accucraft.uk.com/products/w ... am-4-6-0t/
tom_tom_go wrote: Sun Mar 11, 2018 9:06 pm Thanks for the pics.
daan
Post by daan » Mon Mar 12, 2018 9:56 am
Great work as allways, but why do you buy a slomo? With your precision you can build one yourself easily.. I do love the spanner set! Absolutely great..
Post by tom_tom_go » Mon Mar 12, 2018 10:08 am
Hydrostatic Dazza wrote: Sun Mar 11, 2018 9:34 pm your desire can be sated
soon
Not at that price, that's Roundhouse territory...
Hydrostatic Dazza
Post by Hydrostatic Dazza » Mon Mar 12, 2018 8:14 pm
daan wrote: Mon Mar 12, 2018 9:56 am Great work as allways, but why do you buy a slomo? With your precision you can build one yourself easily.. I do love the spanner set! Absolutely great..
Thankyou for the compliments, much appreciated.
There is a lot in the design and making of a Slomo. The gearing ratios, the correct weight, then sourcing the gears, metal and non metal gears and pinions, sorting the bearings............ It would be a long learning process with much experimenting which would delay the day the loco steams. At the rate I am going it will be two more years and adding another 6 -12 months while I attempt to sort my own mechanism would depress me, I have yet to sort the signalling mechanisms for the POR and the lighting etc. For me it was much better to respect what Terry has sorted and created and give him a few gold coins and be on my happy way. I will add that Terry Robinson has been most helpful all along the way.
Post by tom_tom_go » Mon Mar 12, 2018 8:24 pm
I agree, a SSP Slomo is not simply a metal case with cogs and a flywheel thrown in. It has taken Terry years of development and expense to produce a product I would never run a live steamer in this scale without now.
daan
Post by daan » Tue Mar 13, 2018 10:03 am
I do agree with that too, but there have been builds on the forum of cheap China toy momentum mechanisms in carriages which also work sort of likewise and those are not that hard to copy if you can work with precision and have the tools for it.
Roundhouse (p.e.) also makes great steamlocomotives and have spent a lot of time designing it, but that you can make yourself too if you have patience, tools and the skills. It's not a judgement towards the designer of the slomo that his device can be build easily by anyone on the kitchen table, it's the remark that if you are capable of building a live steamer to this grade of precision that an inertia device also is within reach..
Hydrostatic Dazza
Post by Hydrostatic Dazza » Tue Mar 13, 2018 9:41 pm
daan wrote: Tue Mar 13, 2018 10:03 am I do agree with that too, but there have been builds on the forum of cheap China toy momentum mechanisms in carriages which also work sort of likewise and those are not that hard to copy if you can work with precision and have the tools for it.
I am yet to have a steam locomotive move under steam that has come from my workshop, let alone work properly.
and at this moment I have made some wrong turns on the way to the expansion links being a reality .........................
Keith S
Post by Keith S » Wed Mar 14, 2018 4:51 am
... and also, I for one would not blame you for saying "I simply don't feel like it".
I am sure I could make my own "chuff pipe", but I am pleased to buy one from Chris Bird.
I enjoy building my own flying model aeroplanes. Each one obviously needs a propellor, and I am more than capable of carving one from wood. However, I am not interested in doing so. Therefore, the propellor is one thing I choose to purchase, even for a "scratch built" model.
You needn't justify your decision with anything more than "I simply didn't feel like it". You're right, Terry deserves the business. If you feel like giving him your business, that's your business.
Post by ge_rik » Wed Mar 14, 2018 7:28 am
Just been catching up with this thread. As always, in awe of your engineering skills. Really great to see raw lumps of metal being transformed into exquisite miniature components. It does make me appreciate why commercial live steam locos are the price they are, though no doubt they use CNC for quite a few of their processes.
Very gratifying to see that one of my humble scribblings on t'net has contributed in a minor way to the development of this marvellous machine.
Hydrostatic Dazza
Post by Hydrostatic Dazza » Wed Mar 14, 2018 9:17 pm
ge_rik wrote: Wed Mar 14, 2018 7:28 am Just been catching up with this thread. As always, in awe of your engineering skills. Really great to see raw lumps of metal being transformed into exquisite miniature components. It does make me appreciate why commercial live steam locos are the price they are, though no doubt they use CNC for quite a few of their processes.
Yes, your "humble scribbings" are most useful. :D
I am in awe how the Roundhouse mob and others make locos for what is in reality a very reasonable price, considering what it takes to buy machinery (CNC etc), maintain it and pay staff who need holidays and sick days and Superannuation etc. I am sure the owners are not down at the BMW show room every second year ordering the new model. However they have to be profitable to cover for when a CNC machine craps itself, or sales go slow, and then there is design time and development of new product so as to stay relevant in the market.
The costs of business today is crippling. From internet costs to PC and then to the workshop tooling and machinery. Insurances, public liability, let alone the materials and marketing. The time sink that is marketing today in my caper is cruel. I am self employed and the easy days of my caper was the 80's and 90's. We did not how good it was then. Digital disruption is some one else's profit margin. In this age when anything now is washed away by another 24 hours of social media, blogs, websites, twitter ................... the independent manufacturer's message is like a fart in a cyclone. Only a few hear and it is forgotten in seconds. The corporations can smash the marketing world. There is a huge tonnage of new product entering the cycling world every year and the punters who spend half their working day on the internet while the boss is not watching expect us to be able to quote the first name and weight of the ceramic ball bearing in the new (insert brand here) wheel set, and every year. After 40 years I am tired of it all. Highly commoditised .......... I would like to sit down at a pub and hear the story from the inside from the creators of Roundhouse over some fine English Ales. The toil they have endured to stay relevant. I can appreciate this. In my caper, I have to remind many that making bikes is not my hobby, it is my chosen path of professional expression. I want to knock off work and get to the Red Room or go camping ! I worked over 10 hours yesterday, and after a lovely meal last night it was hard to get to the Red Room and paint another coat of yellow on the sample signal kit, then start the mill to make another replacement part for the expansion link. I don't know how I did it but I thinned some material to 1.20mm rather than 1.60mm so I have to prepare another piece. These expansion links have been the least favourite part of my loco build so far. Toil, persevere at the toil, toil on. End of first world winge from down under.
Hydrostatic Dazza
Post by Hydrostatic Dazza » Wed Mar 14, 2018 10:03 pm
A wee bit more time on the expansion links last night. A wee file here and there, a wee rub with some grits, finish with 1000 grit.
I am starting to be tired of these links, but that might be linked to general fatigue of working to earn a coin or two and trying to keep the project creeping along.
Post by tom_tom_go » Wed Mar 14, 2018 10:13 pm
Take a break from it if it's becoming a 'job' to build the loco.
Hobbies are meant to be picked up when time and enthusiasm allows.
