RWLR - Robin Wood Light Railway
- DolwyddelanLightRail
Good progress has been made over the last month as I am finally now onto the curve which will lead off to the main line:
I had to add an extra batton along the fence to support the track shelf and where the apple tree is the fencing behind it needed doing again after a hash I made of it the first time!
The track templates I made show you the curve starting off at a 4ft radius and then working it's way round finally to 5ft.
Also, roofing felt has now been added to the steam up area which will eventually be ballasted and a slight lip added around the edge:
And finally here is where we are heading, ONWARDS!
Despite my best efforts the raised surface is not level so I am wondering how to make the track level without constantly having to adjust ballast? I also don't like the idea of banging nails into the sleeprs as they will show.
I did have a play with putting screws under the sleepers, however, it's impossible to get a perfect level without making sure every screw is in the right place!
What does everyone else do please?
Tom
RWLR
Tom
RWLR
- Sir Clothem Cap
How do you overcome unevenness though on your lines?
I have gone along with a spirit level placed on the sleepers at various points and I have variations all over the place (this is without ballast so far).
Does it have to be perfect? I use R/C but I have to keep playing about with the regulator for smooth running
Tom
RWLR
Tom
RWLR
- Pendo Pilot
- Pendo Pilot
- Sir Clothem Cap
This is part one (steam up area) nearly finished:
I have also started using Cliff Barker fishplates rather than the Peco offerings:
Once painted I think they will look the biz.
Unfortunately, my rail bender has decided to start producing kinked track so until that's sorted I can't do much else for the moment.
Tom
RWLR
Tom
RWLR
I perfected my 'screws under the sleeper' method of laying track (yes I know I make work for myself)
It does give great results though for level running and also means you cannot see any nails/screws through the sleepers:
Screws are positioned every forth sleeper and because the track is webbed there is no sag when trains run over the parts with no supports. I will ballast these in later anyway.
Another benefit of using screws means I can adjust the track when required and because the track is raised it will create an embankment either side of the sleepers once the ballast is in place - just like the real thing
I completely agree with the enjoyment of hearing the loco's work which is why all my rolling stock is heavily weighted and chuff pipes a must!
Is it just me but those of us that work full time and have busy family lives find that their railways take years to build like mine is at the moment?
Tom
RWLR
Tom
RWLR
- Pendo Pilot
One of the plus points of working mad shifts helped me do mine. Getting home at 11am after a full day or not starting till 7 at night for example. It's all good.tom_tom_go:59541 wrote:I Is it just me but those of us that work full time and have busy family lives find that their railways take years to build like mine is at the moment?
Tommy Dodd may have an ARS key but I have a TASS button & a Rope Ladder, just like pirates, except the TASS button bit.
