The DVLR Mark 2
- taliesin001
- DolwyddelanLightRail
- Sir Clothem Cap
- Pendo Pilot
- Dr. Bond of the DVLR
- Retired Director
Thanks for all he comments! The line is rather too short at the moment, even shorter than how it appears in the video. Next to be extended is the Holesley branch (the bit the train reverses down having gone out of Woodbridge station), that will go all the way down to the end of the flowerbed and under Woodbridge town and should end in a quarry balloon loop. Yes, I am having a quarry! Not of the type you'd be thinking of though... Its a Phosphate nodule quarry. In the Suffolk rock (Red Crag) there are lumps of phosphate which Victorian geologists believed to be fossilised dinosaur poo. It was discovered that by dissolving in sulphuric acid it would make a valuable fertiliser (most important to an agricultural area) Superphosphate. The quarries would only have been around 10m deep at most as reg crag is found above a layer of London clay and is reasonably shallow. This all gives me the perfect excuse to have another station, an unfeasably tight radius balloon loop and some nice dirty, stained mineral wagons. I love my loco area!
- Retired Director
- MDLR
You might want to take a look at the stuff Richard Stacey does:
http://www.richardstacey.com/welcome.html
It's nice, but pricey!
- taliesin001
Alternatively you could look at www.minaco-uk.com , someone built a station from a jacksons miniatures kit and clad it with these bricks. Not exactly the right scale but the 1/24th scale ones look good
- Retired Director
Well, the cats seem to be doing there bit for renuability, ensuring there is fossilised poo in the garden for many years to come grrrr.prehistoric $#!t tip
Anyway...
Been working on the branch line to Bordsey quarry with another two lengths of track down. The railway on this branch was layed very lightly and is not expected to see much passenger traffic. I had to build the track behind my rose and infront of mum's tree like plant (name escapes me) so the railway has developed a nasty double S curve of rather tight radius! Still, it all adds to the light railway image...
My two layers of bricks method of laying track seems to be working well providing a sturdy track-base. In these pics I have yet to water the ballast to make it go off so it looks a little bright!
Looking back up the line
Do check rails go on the outside or the inside?
Clearance testing.
- plewsy2105
- Pendo Pilot
Yep inside of the two, as in between the two rails & on the tighest radius side. If thats not clear enough. Only ever seen two check rails in standard gauge anyway, on bridge tops (where you also sometimes get rails on the outside of the running rails as well.
You could always make some 16mm greasepots/flange oilers whichever you prefer to call them for those tight S curves. I was trying to on my return curve before deciding it was going to be lifted anyway. Some vehicles flanges rub like mad on that & I found smearing grease on the inside of the outside rail helped it go round.
Nice update anyway, coming together piece by piece. Whens the next installment out anyway?
Tommy Dodd may have an ARS key but I have a TASS button & a Rope Ladder, just like pirates, except the TASS button bit.
- Retired Director
Thanks, I'd got it on the outer most rail! Funny that as I've seen them so many times on NG lines but never noticed which side they went on! It was just a funny idea of mine, "I've got some rail kicking about, bend to shape, check rails voila!" Next for the line is a tunnel, I'll be doing one of the biggest no nos known to garden railways...
Curve in a tunnel...
