The DVLR Mark 2
- Dr. Bond of the DVLR
- Retired Director
It was left for a whole term while I was at University (two months)
So, I decided to mock up Woodbridge again with cardboard that tomorrow I will try and make from ply wood properly. I have a good supply of window frame materials and glass ready to go. Laurence was saying how he missed "Catchit Tunnel" and it got me thinking. I originally got rid of it as it was too "hornby dublo" ie the hill looked two artificial and was too steep (The original idea behind it was to make maximum use of the space and put the Woodbridge buildings on top of the tunnel. So I thought, why not make the back branch THROUGH the buildings yet keep it so that from the "trains'" points of view it is going through a perfectly ordinary cutting/tunnel arrangement. This gives me a chance for another row of buildings which I decided could be the thoroughfare, as the actual street is quite short the plan is to add mirrors at each end to give the illusion of a much longer street in a small space. Please excuse the dodgy cardboard and sharpie mock ups but they really help me to "See" what goes where.
The first row of buildings by the turntable
The cut through to the thoroughfair
A view down into the narrow street
The other side of the station has grain wherehouses
The whole arrangement
That's the woodbridge side, from the "bawdsey branch" side looking towards Snape Street
Looking towards bawdsey (the backs of the buildings will be disguised by craggy rocks and plants)
The railway will go through these buildings here
What I am most excited about is all the different roof lines there will be and lots of chimney pots (The view from my window is all wobbly rooves and chimney pots)
That sounds like an amazing use of space! Great idea!
If it can be made full scale it can be made 16mm
My line: http://gardenrails.myfreeforum.org/about7200.html
- laurence703
- Retired Director
Now in plywood flavor!
Made a quick mock up with the new plywood bits I cut out. (just stuck together with Copydex.
Remembered that the pub has an over hang so added that in
Hopefully this picture explains a little better with the tunnel
All rough cut at the mo, did check that my most out of gauge peice of rolling stock does fit
This plywood was a rough off cut I picked up for 3 quid at the local Jewsons
At peterborough I picked up a great big box of resin bits. Here's another small building for the quay
- St.Michael
I really like to follow your sides and the development of the line It has struck me that one important thing on your railway is the light (or the lack of it) It gives a very spesial atmosphere. I´m also fascinated of your house-tunnel: I love it Have you thought about the smoke comming up from the chimneys when a steam train runs through?
With regards Michael
- Retired Director
I do indeed have a plan for chimneys but that comes later...
Progress,
Small hut was painted:
Windows and door ways cut out
A former for Tunnel size was made out of polystyrene
Then I thought "eh up, these could make nice tunnel mouths..."
Ping!
Thin bricks used for the tunnel walls
Broken pots for the rooves. I also did alot of work today on some metal sheeting from an old microwave. it is to hold the soil up and form a barrier between the soil and the buildings to A protect the buildings and B make sure that if the buildings are removed, the soil will not all fall in. Sadly I had no appropriate saw available so had to chain drill and file most of it which took an age...
Progress,
Ping!
- Lner fan Sam
- Retired Director
More progress on the Woodbridge development. I hope things are starting to get a little clearer...
The Bawdsey tunnel mouth
Yes, it does fit...
The top of tunnel view...
RB bursting out of the tunnel
Woodbridge starting to look more complete, still bare plywood and cardboard mock ups though.
Here is the afore mentioned metal sheet which holds the soil up even when the buildings are removed. It used to be a microwave casing...
It was a dear to cut out, I had to resort to chain drilling and filing
Yes, it does fit...
- Sir Clothem Cap
- laurence703
- Retired Director
- Retired Director
New little bit of pregress on the buildings, shells are basically done now so its detail time!
Nearly finished painting one of the model town low relief houses, I wonder why it is that colour?
Started to apply the timber frame to the pub.
The sweet shop gets all its detailing and is now ready for water proofing
Impressive progress, great idea too. Those houses and shops need a nice cobbled street or something to sit on, wonder whether you could use the same technique as you used for your tunnel mouths to create one?
What do you use to waterproof? I'll be making some ply buildings of my own at some point and have been pondering what to use...
- Retired Director
I just went to the local hardware shop (its quite "four candles" in there) and asked for some wood preserver. Its a horrible fluid which is brushed on, reeks to high heaven and seems to get everywhere by capillary action. I know this isn't very helpful and I don't know if it works yet as I haven't had the buildings long enough to know!
- Retired Director
- Retired Director
Was just about to ask if that check rail was a working one or not.... Guess gravity glue answers that question
