(WH)WHR Rolling Stock
Re: (WH)WHR Rolling Stock
Post by LNR » Sun May 31, 2020 2:05 am
I agree with Rik, it's not easy to cut out windows and have them all as even as yours. Great work.
Post by FWLR » Sun May 31, 2020 7:50 am
A masterclass on cutting ply Andrew. Looks like another fantastic build coming again from your workshop. :thumbright:
Rod
Life is so easy when I run my trains. :thumbright:
Chairman
Chairman
Post by Andrew » Mon Jun 01, 2020 11:02 am
Thanks chaps, glad you approve of the work so far!
I'm afraid I seem to have chosen a very flattering angle for the photo - if you were to look closely you'd see all sorts of wonkiness! I like to think it adds to the light railway charm...
cncmodeller
Post by cncmodeller » Wed Jun 24, 2020 7:45 pm
It doesn't matter if there are any wonky bits as long as you do a nice job of the painting! If you feel the need to reach for the toilet brush and emulsion paint like most 16mm modellers just stop and do it another day. Just look on Ebay and you'll see what I mean.
I always use two coats of sanding sealer rubbed down in between then a good coat or two of cellulose primer then a top coat, this is usually done with a spray gun as you get a nice even flow compared to a fluttering spray can.
I've found a good source of masking tape too, It's a 50mm wide roll of what's called 'professional tape' by Tesa about £10 it's exactly like that expensive Tamiya Tape with the same charactistics but if you are using cellulose you do need to give the paint a couple of days at least to harden otherwise the tape will mark the paint.
John
Chairman
Chairman
Post by Andrew » Fri Jun 26, 2020 11:42 am
I couldn't agree more! Thankfully, that's the bit I can usually do relatively well, so I can bodge away feeling relatively confident I'll end up with something I'm pleased with ... Thanks for the tip about masking tape...
I've made a little more progress with the latest project (seats and ends) - photos of that and other projects soon!
Chairman
Chairman
Post by Andrew » Fri Jul 10, 2020 12:54 pm
Hello all,
It's been a while, but here's a quick update...
There's not much progress to report on the Ffestiniog brake composite, but wandering past the carriage and wagon works yesterday revealed that a second carriage project appears to be in progress - a somewhat mysterious one...
Most of the carriage was tucked in the shed, with no room to squeeze past to see the rest - and the staff were keen to send me on my way. Why the secrecy? Who knows? I looks like the beginnings of a perfectly ordinary carriage - ply, stripwood and Big Big Train bogies... We shall see...
In other rolling stock news, inspired by another thread on here I purchased a kit for the Ffestiniog one plank "beer wagon" from Phil Sharples. The main problem with his kits appears to be that they're crazily good value for money, so I found myself unable to resist purchasing two more at the same time - a flat wagon (to form the basis of the Welsh Highland drop-sided open that JMORG's also modelled recently) and a freelance brake van (because I really like brake vans). Here's progress so far:
I've changed the coupling arrangement on the beer wagon (doing a chameleon impression against the red tablecloth in this picture) and opened out some existing tabs on the other two to allow space to use 24mm wheels instead of the 20mm ones supplied. The brake van has a little added detail but is almost complete, with the flat trailing behind at the moment. We've got a busy weekend, but I hope to get time for some more progress on these next week. The kits are very well designed, and I'm surprised how much I'm enjoying working with MDF too - more may follow...
Chairman
Chairman
Post by ge_rik » Fri Jul 10, 2020 1:32 pm
Excuse my ignorance, but what is a beer wagon? Did it carry beer, or is it the Welsh equivalent of a 'bier' - ie for carrying coffins?
JMORG
Post by JMORG » Fri Jul 10, 2020 6:40 pm
The FR beer waggon is a replica of a single plank "general purpose" waggon from the old FR. Originally when the replica was built it was used a lot for carrying the Purple Moose ale in casks for Spooner's; now it's gone back to a general purpose demonstrator waggon.
Limitations only exist if you let them.
Post by FWLR » Sat Jul 11, 2020 8:24 am
Looks like you are really going to busy Andrew. Interesting build in the first photo. Can't wait to see what it turns out to be.. :scratch:
Rod
Chairman
Chairman
Post by Andrew » Sat Jul 11, 2020 10:28 am
I think Purple Moose sponsored the construction of the replica, because there's a photo of the original carrying beer barrels - they specified the livery too, but mine's going to be in traditional FR brick red.
As well as barrels, the (WH)WHR Operating Department are eying the wagon up for the annual plum trains - it should carry a fair few and the low sides will make for easy loading... The plums are ripening now, so I'd better crack on with it!
Chairman
Chairman
Post by Andrew » Fri Jul 24, 2020 3:18 pm
Hi all,
Sorry, haven't been terribly active on here of late - I've got lots of threads to catch up on over the weekend!
In the meantime I thought I'd share a couple of photos of the first of the Phil Sharples kits I've completed, the guards van. It's more or less a straight build, just with a little added detail. I had modified it to run on larger 24mm wheels, but it looked a bit like it was tottering about on high heels, so it's gone back to 20mm ones again - the coupling height still seems OK.
Here it is:
Pleasingly quaint, I think? I'll try to give it a test run and take a few photos over the weekend...
Chairman
Chairman
Post by philipy » Fri Jul 24, 2020 4:15 pm
Nice Andrew.
Post by FWLR » Sat Jul 25, 2020 11:16 am
Neat that Andrew. :thumbleft:
Rod
Chairman
Chairman
Post by ge_rik » Sat Jul 25, 2020 2:32 pm
Nice looking model. The guard looks good too. He has a nautical bearing....
Chairman
Chairman
Post by Andrew » Wed Jul 29, 2020 6:00 pm
Ah! Am I right in thinking that you've spotted the guard's origins Rik? He's a McDonald Happy Meal figure of Captain Haddock of Tintin fame. I barely had to make any mods at all apart from repositioning one arm, but he does still look like he'd be more at home on a trawler! Given that the van boasts almost no mod-cons, no glazing in the cabin door, let alone a stove, I thought a jumpered guard was quite appropriate!
I've just finished the second Phil Sharples kit, a flat wagon to which I've added a plywood body to represent a NWNGR drop-sided wagon. The idea was to use the kit as a bit of a short-cut, which worked, but at the expense of it not being a terribly faithful replica of the real thing, the proportions are all wrong. I don't mind much, I like the chunky look of the wagon, which will be used mostly to carry granite.
I've got a little stuck with the remaining Sharples kit, the Ffestiniog beer wagon. There's not much to do really, I've just lost momentum with it. I'll look down the back of the sofa, most things seem to end up there...
