1:12 scale Regner Vincent
- jez kirkwood
Hi Matt
Most of the woodwork is hardwood off cuts (mostly from old furniture) cut to size on my bandsaw, then distressed with a wire brush wheel in a cordless drill which is then painted with vinegar which has had rusty nails/wirewool added to it. this looks rubbish when you brush it on but the next morning looks great! The planking on the cab is ice lolly sticks treated in the same way. The metalwork has all been treated with 'Rob & Si's blue jollop' which is availiable from Modelearth Designs and Busybodies.
- St.Michael
- jez kirkwood
Hi Michael, I moved the gas tank to the other side of the footplate on mine which puts the driver well within reach of the reverser!, if you go for the Konrad the cylinder (and thus reverser) is oriented in such a way that it is easy to fit a standard reverse lever in the cab with a link to the cylinder block reverser arm. There was one for sale at Telford this year that was fitted like this.
