Hi folks,
One potentailly sick Accucraft Caradoc here.
So, standard Accucraft 040 chassis - the cylinders aren't meant to move slighly back and forth while they're in motion are they?
Also, look at the cylinders - there's the cylinder of the actual piston housing, and the little cuboid directly above it. Is oil supposed to seep out of the seam between the two?
Lastly - looking underneath the loco at the steam chest getwene the cyls and frames, are there supposed to be two holes there? Or is this part 'yes' and I'm just being dumb as I hadn't steamed the loco in 5 months?
If not, what can I do about this? I can't find any bolts/nuts that are accessible in order to tighten up. Might this warrant dismantling the loco? Or a pro?
Accucraft Cylinders
The cylinders shouldn't really move when in steam but it can happen, there should be two bolts holding each cylinder to the frames.
The oil leaking is comming from the join between the cylinder and piston valve. You can try tightening the bolts holding the two parts together to stop it but I wouldnt worry about it till its gets really bad as in means stripping most of the loco to get at them.
As for holes in the reverser I couldnt tell without a picture.
Dan,
DLR
www.freewebs.com/dlrail
DLR
The oil leaking between the cylinder and the valve chest (the cuboid bit ) is due to the four screws fastening the two together not being tight enough. My RAgleth ahd the same problem. Started as a slight dribble and then pissed steam and oil all over.......
It required a total strip down to get at the screws and new gaskets....so a big job.
