bambuko loco works 0-6-2 (Fowler)
Hydrostatic Dazza
Re: bambuko loco works 0-6-2 (Fowler)
Post by Hydrostatic Dazza » Thu Dec 05, 2019 7:31 pm
You are doing such a nice job, put a grate in and burn the black stuff.
bambuko
Post by bambuko » Thu Dec 05, 2019 8:35 pm
Thank you.
I would like to do it indeed :thumbright: but this particular model would need too much butchery to rear of the cab to permit easy access for the shovel.
Plus, adding axle pump at this stage would be a bit of PITA
I will leave it for the next one :mrgreen:
Having said so - this mod is not impossible and the way this project is meandering you never know where it might end up :D
bambuko
Post by bambuko » Tue Dec 10, 2019 6:28 pm
Something slightly different (i.e. no update, although I am making progress :thumbright: )
Here is one of the original, Leeds build Aussie Fowlers that made it's way back to UK:
She is in "Steam Workshop":
https://www.steamworkshop.co.uk/portfol ... ler-16341/
and here as she was in Australia:
http://www.australiansteam.com/fowler16341.htm
and more photos:
http://www.steamworkshop.co.uk/portfoli ... s-fowlers/
Shame I got the vids and photos only now and not when I was designing my model (which suffered from desperate shortage of decent photos of original)
OK, she is 0-4-2 not 0-6-2 (which I am building) but other than that she is much of the muchness...
Not surprising since someone like Fowler wouldn't be re-inventing the wheel every time it build a locomotive :mrgreen:
Lot of common components and familiar design aspects.
Hope you guys enjoy it as well :study:
Hydrostatic Dazza
Post by Hydrostatic Dazza » Wed Dec 11, 2019 8:46 pm
Thank you.
There were articles in AME magazine in 2017, they did thermal modeling of what happens in a coal fired wet leg boiler when run dry. The temperature rise was very little and well within the brazing and copper material stability, due to the draft on the fire ceasing as soon as the water was gone. thus in the small garden size grates, the fire dies to a ember. (if you use soft solder well ??) They backed this up with actual testing and measuring temperatures and all was very close to the thermal modeling. I saw this in action on the loco at my local ME club run. They have a small garden track there now. I know many will be :roll: with the concept of a coal fired garden steamer without a pump, but like many things, once the notions are wide spread, then the notion is all blanketing and perpetuated for decades it is hard to dispel. So maybe you do not need a pump if the boiler has wet legs and the design has a decent water volume for long runs. (less tubes) I am putting a pump in my build to just give the option of a lengthening the run, thinking it will be 30 -40 minutes with a slow trickle that will be just below the steaming rate. Still able to run it dry, it just gives more wine and smelly cheese time . Did I email the scans of these AME articles to you ?
Last edited by Hydrostatic Dazza on Thu Apr 16, 2020 11:08 pm, edited 1 time in total.
bambuko
Post by bambuko » Thu Dec 12, 2019 11:12 am
...There were articles in AME magazine in 2017, they did thermal modeling of what happens in a coal fired wet leg boiler when run dry ...I saw this in action on the loco at my local ME club run...
How does it square with the boiler code which requires you to have two independent sources of feedwater (regardless of boiler size)?
I am not saying that the article was wrong, simply asking how can you run (in a club environment) something that does not adhere to the code?
What you run in your private back garden is your own business, but in public... it's another story?
...I know many will be :roll: with the concept of a coal fired garden steamer without a pump...
Yes :mrgreen: and that's why I think that sharing a boiler code with "big guys" is a bit of a problem.
... Did I email the scans of these AME articles to you ?
Yes, you have - thank you very much!
I personally dislike axle feed pumps in smaller scales, so these articles are very encouraging :thumbright:
Keith S
Post by Keith S » Thu Dec 12, 2019 6:13 pm
Those "Riverdale" boilers don't have feed pumps. Apparently designed to carry enough water to last until fuel exhaustion. I wonder if the design takes into account that the fire will die when the blower stops. I've seen them running at expositions in public, so must be insurable at least under the 16mm association guidelines.
bambuko
Post by bambuko » Thu Dec 12, 2019 7:36 pm
Yes, just been through Riverdale webpage.
The arguments (with which I totally agree) against the use of axle pump are very well explained by Brian Wilson in this August 2014 article in "16mm Today" magazine:
https://www.riverdale-loco.com/Today.pdf
So I guess, you are right - it is acceptable to the insurers etc.
Makes a mockery though of the boiler code we are supposed to adhere to? :scratch:
TonyW
Post by TonyW » Fri Dec 13, 2019 2:51 pm
I'd forgotten about that article, so thanks for posting the link. I have a Shawe Steam Services / Roundhouse "Jack" which has an axle pump. I must be doing it all wrong.
For clarity, to which boiler code are you referring?
bambuko
Post by bambuko » Fri Dec 13, 2019 4:06 pm
...For clarity, to which boiler code are you referring?
in UK - The Boiler Test Code 2018:
6.5
Boiler water feed arrangements shall be by at least two independent means
(two of each, or a combination of, hand pump, injector, mechanical pump, etc.).
A single boiler inlet with two check valves is acceptable.
later edit:
Correction - above is from Volume 1 (for boilers above 3 bar litres), so it doesn't seem to apply to "our" boilers, which are covered by Volume 2.
The only reference to boiler water feed in Volume 2 is as follows:
The boiler may also be fitted with a water level gauge and a mechanical means of pumping water into the boiler whilst under working pressure. If no means of supplying water to the boiler whilst working is present, the fuel supply shall be so arranged that it is used up before the water is exhausted.
So it seems that it is all optional? :D
in Australia - AMBSC Code Part 3:
2.5.3
The boiler shall have at least two feedwater systems one of which shall be an
axle pump or other device that will maintain water level while the engine is in operation.
later edit:
This one definitely applies, regardless of size of the boiler (AFAIK)
Hydrostatic Dazza
Post by Hydrostatic Dazza » Sat Dec 14, 2019 8:58 pm
“in Australia - AMBSC Code Part 3:
2.5.3
later edit:
This one definitely applies, regardless of size of the boiler (AFAIK)”
You may be looking at the incorrect document, are you referring to sub miniature boilers
AMBSC Code part 3
Issue 2.00 -2017
Sub- Miniature Boilers.
(which is the latest one that I know of)
There is no mention of 2.5.3, it actually does not exist in the document I have. (last listing in section 2 is 2.3.14)
There is no mention of feed water systems at all in the document. I have not seen many meth fired pot boilers with hand, axle pumps or injectors.
I will also add that as an engineering document it is has many problems. One example, there is no reference to boiler barrel wall thickness. It has been reported by others that the process of creating the current AMBSC sub miniature boiler code was fraught with problems, even contempt for the smaller scales and submissions by those who work in the smaller scales, so there are moves to create a new separate code for sub miniature boilers.
bambuko
Post by bambuko » Sat Dec 14, 2019 9:41 pm
I am referring to the same document, but I haven't got the latest version (mine is 2006), so it might be that it has changed...
Section 2.5 (in 2006 version) is Coal Fired Boilers
Yes, I am aware about the moves to create separate code.
bambuko
Post by bambuko » Thu Apr 16, 2020 1:26 pm
Trailing pony truck.
The combined truck bearing/gas burner holder:
Outside fames with bearing pad:
And the same from below, with wheels, axleboxes and springs:
Pony truck assembled and ready for fitting to the loco:
Detail of axlebox:
Pony truck secured to the loco:
On the rails:
and that is prototype ve model:
The springing is very light, just enough to keep trailing pony wheels in reliable contact with rails, without affecting main wheels.
Tested on some dodgy track and delighted with the way it works :thumbright:
Post by tom_tom_go » Thu Apr 16, 2020 1:37 pm
Very elegant!
bambuko
Post by bambuko » Thu Apr 16, 2020 2:15 pm
Thank you ttg
btw - more updates from the restoration of full size Fowler at Steam Workshop :
Hydrostatic Dazza
Post by Hydrostatic Dazza » Thu Apr 16, 2020 11:25 pm
Marvelous stuff with the truck. Keep the photos coming !!!
and the video is interesting. I would have invested in a needle gun to clean up the wheels etc.
I know the feeling of tube grinding in the fire box.
