Llewellyn Loco Works #1
- Hydrostatic Dazza
Re: Llewellyn Loco Works #1
This is not going to be a fine scale working model, I leave that to the incredible Cherry Hill. It is all a process to learn and arm myself with the knowledge and tools to make a super 5" gauge QR C17 loco in the years come.
However cheese head screws on buffer beams looks like a gooba dripping from one's nostrils in public. So it was again inspiration from a ME forum that I make a prototype rivet chopper.
Fake but I reckon the beams look a a wee bit better with 1/16" rivets
- Hydrostatic Dazza
Cylinders commenced
A think through the drawings and sort some details.
Gun metal stick
saw saw saw saw saw
"Listen up you silly Galahs, don't screw these up!"
Rough out to size which is a process that I most dislike with machining.
Drill, bore, ream. A cylinder drawing should have the bore diameter shown, eh! There is some conflict with sizes with text and drawings. I went for 12.7mm bore.
Rear covers. In hindsight I should have gone to 12 BA and made it for 6 screws rather than 4, just to look nicer. But next time. Again I think Cheese head cylinder cover screws are a bit errrrr. So easy to swap them out for hex head. Yeah, they should be studs but................................
I actually did mess up one cylinder early on, cursed my self and smoothly processed another one and this went quickly.
Setting up for drilling
Never coffee here, always tea, besides the wine and beer. I am a fan of many Pommey real ales!
Front covers. I made a special split holder from scrap laying about and it worked a treat.
I used the trepanning tool that I made for use on the wheels. Well worth the effort to spend some time resource on grinding tools and storing them correctly so they can pulled out in a moments notice and put to the task. YAY!
Drilling/taping the rear covers for the slide bars, in alignment etc.
I had to fit them to the frames for kicks and giggles.
Now this is when I find the driving crank pins are slightly out of alignment. Just a tad of bind. I confirmed it is not the quartering , but one of the pins. Annoyed but not a deal breaker. I have aimed for close fits and so far I have not needed to ease fits or file holes.
Gun metal stick
saw saw saw saw saw
Last edited by Hydrostatic Dazza on Mon Oct 16, 2017 10:40 pm, edited 2 times in total.
- Hydrostatic Dazza
I pondered over the gland nuts for piston and valve. Hex heads, nah. Dug about for scraps of PB.
I some times skip out of work/home and do some volunteer work related to the struggling Rosewood Railway and Mary Valley Rattler. A visit to the Ipswich Heritage workshops is also fairly regular in my monthly life.
#1089 in steam, soon to depart for a charter (BB 18 1/4 Class) The last steam loco built in Australia for a government railway.
DD17 tank loco's frames , await its new welded boiler.
Rosewood Railway are the custodian of RM64 "The Bug" and it is getting $35,000 worth of attention via a grant we won for the railway, YAY!
Last edited by Hydrostatic Dazza on Mon Oct 16, 2017 10:43 pm, edited 4 times in total.
- Hydrostatic Dazza
MAM's late father was a journey man machinist in Detroit, he make robots that machined engine blocks for the Ford plant etc.
He gave me a box of old bits and pieces and one of them was an old dial indicator.
Rummage about for some scraps, and hour later
Super fast and accurate tool centre height thingy for the QC tool holders. (Thingy = Dazza technical term)
- Hydrostatic Dazza
For the steam chests, missing dimension for the off set cover hole for the admission passage. I nearly missed this and I would have been cursing if I did. If you look at BW's drawings you can see the off set hole lines, but no dimension or text. I am not going to use bolts, after only using 4 cover screws I thought I will have a go at 10 BA studs to hold the chest cover and chest to the cylinder. So again I make a prototype screw stud trimmer.
Then onto the valve cross head. Roughed out, machined but not finished. I could not find a mention of how the stainless rod is attached. I am going to silver braze.
Again some filing buttons were made and used and then stored away for possible use later on in life.
Piston. Gunmetal not brass for me.
Shaving tool to chase the 0.005mm. The bores measure 12.72mm post reaming. I machined the piston 12.71mm. I wonder if that is enough clearance ?
A suggestion was made to me to try Quad rings rather than O rings. They sold me the benefits so, heck why not ? However the depth of the groove needed to be deeper than what the the data sheets were telling me. I ended up spending a lot of time to sort this. Trail scrap pistons were made and many careful measurements made, Eventually I am satisfied with the smoothness and light pressure to move the piston. The ring has sealed from the bottom of the groove as required. We will see if in service it works OK. The worst is I have to remake the pistons with O rings. I am new to world of O rings and such like. I ground up a parting tool blade and tested the result so it is a one plunge cut. If you make sideways trim cuts the sides of the groove will not be straight as the tool will deflect. Is this worth bothering about, probably not but it takes only takes 30 minutes one evening to grind a tool up.
Last edited by Hydrostatic Dazza on Mon Oct 16, 2017 10:46 pm, edited 5 times in total.
- Hydrostatic Dazza
A little parcel arrives via the post. The workshop mob gather around for a gander.
I am working with Mike in NZ on some bike frame casting prototypes and I sent him some drawings and he printed off the masters for some investment castings.
Bingo, I have some Silicon Bronze steam chest covers. (and a few spares to go to another worthy home , wink)
- Hydrostatic Dazza
While all this is going on I am checking the valve gear. Now please do not get me wrong, Brian's books is marvelous and a great source of inspiration and information, the big difficulty I have is the valve gear and layout. The book does not provide a valve gear/motion general arrangement drawing that is correctly or fully dimensioned. The Page 37 drawing is not fully dimensioned and the 88.0mm dimension from the front of the frame to the motion bracket mounting screws does not measure correctly. It seems closer to 92.00mm. Also there is a mismatch of fits and sizes due to rounding out of metric sizes from Imperial, not earth shattering but one needs to think these out. I reverse engineered the motion bracket location from the dimensions of parts and the motion bracket and bent up slide bar, (I am going to use a separate slide bar) but I cannot confidently confirm the layout as there are assumptions to be made so one can fill in the missing dimensions. There is also some errors to be seen in the page 37 drawing but of course, these things occur and can be sorted and thought out and we move on. So I come to what I think is the valve gear layout. However my CAD model shows some bad valve events. I confirmed this via the Docstrader program/model. If I get reasonable forward events I have impossible reverse. I have heard that others have had this trouble with their Eric locos, but is all this the builder's errors ? Is it my errors ? What is required is a fully dimensioned valve and motion drawing of the necessary pin locations etc in relation to the driver centre. Of great assistance would be a simpler version of this.
Of course we do not need as much detail, just the theoretical locations and lengths of the parts. So one can reference off to see where we have drifted with our dimensions on the parts or our mistakes. The tweaks can then be from that.
I am new to the the understanding the geometry of Walschaerts motion, so the books come out and I study and read and struggle with Don Ashton's writings and Martin Evans and others. I come to the conclusion that a redesign is required. The correct radius rod length to match the expansion link radius, anchor link alterations, allowing for the valve rod inclination with the return crank setting, moving the expansion link trunnions centre. Various other tweaks. I also altered the slide valve dimensions to assist with a better mid gear setting, the combination lever will always rock the valve but the ports stay covered, along with a few other things. I devoted many evening hours to this, realising that this is all good education regards my hobby time with full size heritage steam. I loaded up my version into the CAD model and the Dockstrader program. BINGO. It all fell into place. The events and cut offs were sweet. YAY!
OK. before I get cocky, I am yet to complete this loco and steam it and thus prove the Pudding is sweet or I have made a total mess !!!!!!!!!!!!!!!!!!!!!!!!!
I am just telling it as I find things with my little choo choo journey.
I also altered/reversed the lifting arm and reverser set up so the reverser is forward in the sector plate when the valve gear is forward. (It was like this in the Edwin design) Anyhow I will let you all know if I have made a mess of this when the time comes to set the valves etc. Now I know Brian Wilson frequents garden railway forums and understand he lives 2 hours drive from me but I have no contact for him. So if Brian is out there wants to contact me, to chastise me or other wise I welcome the call. 07 3353 3368. The book is terrific and it drives me , gives me direction. I will also add, I have no commercial interest or desire to make $ from the garden railway world. It is just one aspect of my model engineering hobby. Did any of that make sense ?
Last edited by Hydrostatic Dazza on Mon Oct 16, 2017 10:48 pm, edited 9 times in total.
- Hydrostatic Dazza
Prototype slide valve. Gunmetal.
Rubbish slitting saw, I have tried two and they are rubbish. I have a soft 3MT blank that is destined to be made into a nice slitting saw arbor, soon!
Rough out the exhaust pockets, made a spare, final pass was .05mm climb mill.
For the valve rod I followed the words and music, 1/16" (1.585mm) stainless rod and run a new 10BA die over it. However this raises the thread diameter to 1.68mm which is close to the correct size for 10BA. The material is moved and pushed up into the die to become 1.68mm. This now will not pass down the 1/16" hole in the gland nut or the steam chest. One can fiddle the thread, knock the crests off, but that will make a sloppy fit as it screws into the valve. Slop/lost motion gives one late valve events. I ponder a solution. A valve nut with the pinch screw is my solution. It worked a treat and is very secure. It also allows the valve to lift and condensate can escape just like the bigger models.
I have stainless screws for the pinch screw when the time comes to fit up on the loco.
That is to date where I am on this journey. The parts box is filling up.
So you will not hear much from me for a while as I go back to the civil engineering part of the POR ( Potters Orchid Railway )
Cheers
Cheers
Wow!! I'm quite exhausted from reading this thread.
You really must be congratulated on the effort that you have put into this project, not least the actual photographing and recording of each stage. That alone is worthy of a 16mm Oscar (is there such a thing?).
There was me quite proud of my humble attempt of minor modifications to my Ragleth, which I was going to record on here but I don't think I'll bother now
I'm certainly looking forward to any future threads on this build.
Its rare to see that level of dedication in the larger scales let alone 16mm, I look forward to further writings. I am also going to steal that jig for cutting bolts to the same length, simple yet brilliant.
Dan,
DLR
www.freewebs.com/dlrail
DLR
- Hydrostatic Dazza
Hi, I just dumped 8 months of work in one day, sorry about that, the updates will be a lot more spread out, more like one a week. I use a little Cannon IXUS camera for the pics, I have a system from my daily work where I send pics of their frame's progresspandsrowe wrote: ↑Mon Oct 16, 2017 9:15 am Wow!! I'm quite exhausted from reading this thread.
With my 32mm loco build I just save things into a folder and when motivated I load it to my flickr site.
https://www.flickr.com/photos/llewellyn ... 7760739050
For me it is important that one shares stuff, via magazines, internet, in person. I try to be a student of the world and listen to ABC Radio National (is that like BBC4 ?) all day.
In the bespoke frame building world knowledge the builders were very guarded, but that is a backward thinking attitude. This has changed via forums etc. The same with the heritage railway scene in Queensland. There was a us and them mentality. Some of us have devoted time to change that culture. It is changing but there are some crustys that will hold a grunge or beat on the drum of tribalism till they are pushing up the daisies. They are just miserable and failing sods that will take any of their valuable knowledge to the grave.
Please post your "minor modifications to my Ragleth" It all has value. Heck I have not yet completed a choo choo yet!!!!!!!!!!!!!!!!!!!!!!!!! We are all on a different point on our time line.
Last edited by Hydrostatic Dazza on Tue Oct 17, 2017 3:38 am, edited 1 time in total.
- Hydrostatic Dazza
From a previous ME magzine article, to me making my version, sharing the pics, then you or others making one. COOL! Then these are shared, and onwards. Almost as good as shout at the bar .........................
- Hydrostatic Dazza
Hydrostatic Dazza wrote: ↑Mon Oct 16, 2017 11:10 pmFrom a previous ME magzine article, to me making my version, sharing the pics, then you or others making one. COOL! Then these are shared, and onwards. Almost as good as a shout at the pub .........................
Hi Darrell
I'm finding this thread fascinating. I'm not into metalwork myself and am not really a live steam enthusiast, but your detailed report has made me really interested in the progress of your loco.
Just a quick question - as you are starting literally from scratch, did you consider incorporating a flywheel device (similar to Slomo) at some point in the design? I'm assuming it would be easier to design and fit one from the ground up rather than having to retro-fit.
PS - I'm with you completely re using the web to share information, ideas and experience. In my own small way, I have been trying to do this with my blog for the past ten years
PPS - Like you, I have BBC R4 on almost continuously during the day. A lot of the time it's just murmuring in the background but when something interesting comes on my attention switches to it. I find talk radio is great as a background when doing something practical. I also have it on via headphones when playing trains in the garden.
- Hydrostatic Dazza
Hi Rik, at this time I have not given any thought to a Slomo type flywheel, this is only due to my ignorance and thus only just recently gaining any hint that they exist. My wheels are on and quartered so if I have to retro fit I am reluctant to break the axle/wheel bond. Also there is a pump eccentric and then the pump itself and an ash pan for it to fit around. I have no drawings or any thing similar and or actually seen one. However I am convinced. From age 12 I likes see models move at walking speed. We used to try and time how long we could take to get to one end of my HO layout to the other end. Looking at the videos of steamers with them fitted, has me no doubt, every streamer should have them fitted. So it looks like I will be getting a tender mounted one. As I have not settled on the tank/body work yet, it looks like my little loco is going to have a tender. Looks like I will be buying a Slomo some time soon from a fellow Aussie.ge_rik wrote: ↑Tue Oct 17, 2017 7:05 pm Hi Darrell
- Hydrostatic Dazza
also Rik, if my loco works out as a good runner and looks reasonable, I can throw the drawings your way, even if you do not have the 3D program, I have each individual part printed off on A4 and can convert them to PDF for any one. Simple but it does make for a box full of drawings. (I am not a fan of multiple parts on one sheet, I like taking one sheet to the Red Room and scribbling all over it and when the part is completed, updating the master 3D part and 3D assembly and the 2D sheet ) But first I must prove the design modifications and prove the build. This may take a year or two more.ge_rik wrote: ↑Tue Oct 17, 2017 7:05 pm Hi Darrell
- Hydrostatic Dazza
Due to constant rain interrupting the civil engineering contractors at the POR the energies were turned to the Red Room and to knock over a project that has been on the bench for a while. ER25 Collet chuck mated with a machined register on a D3 backing plate for the Myford. First time I have ever done some thing like this, the result was as good as hoped. Next will be a better slitting saw for the mill/drill, I have two commercial ones but they are rubbish and wobble all over the place. I have a blank 3MT arbor and a 3 to 4 MT sleeve so it will machined in the Myford. Keen to get back to completing the cylinders soon.
- Hydrostatic Dazza
Rain all day Saturday so the civil engineering gang stayed in doors on the "POR". The Red Room saw action for most of the day.
Work on the cylinders progresses.
Mike Jack sent me these covers he cast in Silicon Bronze, they were off my drawings and these are the start of the education and processes of using many more castings from my drawings in the future.
I gave them a wee bit of attention with some 600 grit
Then a wee careful mill to get a clean face.
The lads, they look a bit rough and untrustworthy, but they have redeemed them selves from their past and they do good work. The air is bit blue with their language when things do not go quiet right but they figured out a little jiggy for the cover and chest drilling. (jiggy is a Dazza technical term)
The 7.20mm drill is align the steam chest to the cylinder and the frame mounting face. (I like using a datum) Even though I have DRO I carefully marked out the sanity lines, just be to be sure (I am glad I did)
The clamp on the jig is removed and the chest and cover removed but the clever bit is that the cylinder stays held in the vice and the location for the X= 0 and Y=0 stays undisturbed.
Done and happy. You may see that one hole for the 10BA studd to pass through is in a different location, that is give clearance for the inlet to the chest. A detail that is visible on close inspection not noted or dimensioned in the Steam Trains In Your Garden Book's drawings or text.
When the next adventure in the Red Room kicks off I will use the DRO to pick up the holes to be drilled 3.50mm deep and taped 10BA for the studs. Have I said recently how much I like DRO on the mill/drill ?
- Hydrostatic Dazza
Chest stud hole drilled and taped 10BA, ports drilled. Have I mentioned lately how much I like DRO ?
Passage way drilling
nailed it to the bull's eye, tis was a happy chappy when I finished on Saturday evening
- Hydrostatic Dazza
There has been a death in the family.
For 30 years this was my go to good vernier caliper. It was cared for and loved and used for many projects. Made by NSK in Japan.
Yesterday its mechanism went belly up.
It lived a good and useful life. It gave me great value.
Ebay, New Mitutoyo Dial 200mm for $75 inc inc postage. Beats $230 from the local supplier. Think of all the beer that $155 will buy
