7/8ths diesel kits
Re: 7/8ths diesel kits
You can do Rod but it will be bigger than your current stock - nearly 23mm to the foot as opposed to 16mm. This a body only kit so you have to provide your own chassis.
Last edited by gardenrailer on Tue Sep 26, 2017 10:27 pm, edited 3 times in total.
Thanks Derek, it doesnβt seem any point then for me to have some 7/8ths then, but i do like them.
I've got a half built kit for the IP engineering cabbed Ruston if you are interested Tom.
Dan,
DLR
www.freewebs.com/dlrail
DLR
Can you send me some photos please of how far you have got including motor set up.
Last edited by gardenrailer on Tue Sep 26, 2017 10:26 pm, edited 2 times in total.
Got the photos, just figuring out how to post. What is the max file size for the forum's gallery, I'm sure there is a thread but I probably cant see for looking !
Edit: just found it, currently resizing.
Dan,
DLR
DLR
195x80x160
This is as far as I got with it before something else got in the way. The frames are assembled as is the cab, the roof is still loose. Bonnet has the larger sections soldered together though I think there is some detail to add. The chassis is IP's MDF kit, I planned to replace with something metal. As it currently stands the loco is 195mm long 80mm wide and 160mm tall. The rest of the kist is also shown, instructions are still in the drawer.
Dan,
DLR
DLR
PDF lat up against a 7/8th scratch build
- Busted Bricks
Urgh, that laser cutting cries out for some more air assist.
3D printed, time for some wet and dry....
Thanks for this Derek, it shows me the scale difference in perspective...
Sorry to confuse you further Rod hut the Lat is actually 7/8th as well. I will try and get some comparative pictures together.
Wow what is the Green Diesel then, it looks huge, or is it some manufactures have a different scale to work from ... lol.
Sir sir I know!
It's an Accucraft Baguley Drewry that has had major surgery.
That is major surgery indeed....
Hi Derek, have you any comparative photos yet by any chance.
