jackson Sharp > Leek & Manifold coach bash
Thanks AndrewAndrew:107726 wrote:Looking forward to film footage of this lot in action...
Yes, me too. Looks like snow is forecast tonight, though it could turn to sleet very quickly. I'd like to get some more snowy pictures and video if I can and if I crack on with the build I might have them ready for tomorrow. But then, my builds always seem to take longer than I anticipate. Sometimes I know I over-complicate things. I keep forgetting the KISS principle.
Took a little longer than anticipated ....... but I managed to get the exteriors finished off today. They all now have 'riveted' underframes and headstocks. I may fit some cosmetic buffers when I get around to detailing the interiors.Andrew:107726 wrote:Looking forward to film footage of this lot in action...
Here's all three
This is the first one I completed. It has a raised ridge on the roof and the steps are flush with the coach body.
Here's the second open. No raised ridge and the steps are away from the body. Whereas the first coach had hand-drawn stained glass toplights I did them on the computer for the last two coaches (I live and learn).
And here's the brake end.
As promised, I videoed their test run. It was beginning to get dark towards the end - but I think you can get a feel for how they run - including rounding a couple of my sharp curves.
http://youtu.be/6DgshtOSbJ4
Hope you enjoy!
Thanks BrianMDLR:107867 wrote:I did!
It was a bit of a voyage of discovery. You may notice they round the tight curve in the fourth shot rather like Bruce's conveyor. From above, the corners of the roofs just touch each other - another couple of mm longer and each would have levered the other off the track.
Of course, that was carefully planned ......... :?
Hi Rik,ge_rik:107697 wrote: I hadn't thought of lining them. I've only ever used Trimline tape for lining and it's OK but not brilliant. I'm not really confident enough to use a bow pen.
Meant to reply earlier....
Using a bow pen, or tubular pen, is easy enough, getting the paint the right consistency is the trick. Like any technique you get better with practice.
A couple of alternatives you might also consider for lining.
- paint markers like the Eddings 780 paint marker, which is claimed to draw a 0.8mm line (equiv. to 5/8" wide in 16mm scale). The colour range is a bit limited though.
I haven't used paint markers in this scale, but successfully lined a 12" gauge loco some years ago using car touch up paint pens.
- waterslide transfers. Fox Transfers have a range of coach lining transfers for 2 1/2" gauge stock (Gauge 3) which would be near enough in size for SM32/45.
In the past I've made my own single colour lining transfers for HO stock by spraying some clear transfer paper with the required colour of paint and cutting strips with a scalpel, using a sheet of glass as a cutting board. I was able to get strips as narrow as 0.030" with a bit of care.
Thanks Peter.Peter Butler:107873 wrote:Congratulations Rik... they do look great!
I was watching the roof corners during the film and thought they were close, but they do the job and that's the important bit!
Your line looks good too, even at this time of year.
Fortunately, most of the vegetation around the railway is evergreen and so it looks OK in close-up. The rest of the garden is looking a bit sorry for itself, though.
I'd like to learn how to do decent lining. I've got that Wild Swan publication on painting and lining which in some ways put me off. I know my limitations unless bow pens have improved since I did my O and A Levels in Technical Drawing...... However, maybe some of these other gadgets might be easier to use - and I like the idea of using transfers as there's some wriggle room to compensate for my ineptitude.
Wow, thanks Andrew. Must admit that my choice of vegetation is more with railway in mind than flower borders. Fortunately, my better half is very happy with that.Andrew:107898 wrote:Great video, thank you. The carriages look lovely, as does the whole railway - attractive, understated and with that undefinable essence of "right-ness"...All the best,
For anyone who might be interested (or just curious), I've detailed my approach to the construction of these coaches on my blog.
http://riksrailway.blogspot.co.uk/2015/ ... sharp.html
I am certainly not purporting to be any kind of expert - there are plenty on this forum who are far better skilled than me - but hoping that it might help others who want to have a go (even if it's to say, well I wouldn't do it like that!).
