Another Wild Rose Project
- -steves-
Re: Another Wild Rose Project
A little time in the workshop today and a little over the last couple of days.
Pretty much got most of the motion stuff made, other than the few bits that I mentioned before that I have ordered, but will still attempt to build them just for practice when they arrive.
This picture shows most of one side of the cylinders, cross head, steam chest and today I even started on the steam unions. I do have a question there though as I have no clue how the steam pipes are supposed to connect. I have made part of the steam tee and will sliver solder it together as and when I get some 3/32 steam pipe. But, there will be an ME thread poking up, waiting for a union to go on it, what stops that pipe pushing out, is it somehow flared over? Is there a special kit for that? I have one to do brake pipes, but is there a special one for 3/32 and as I have no countersink what stops the steam just escaping? See loads of badly phrased questions that no one will have a clue over, lol.
Oh the picture, ignore the black pen, it's just for reference to get things on the same way they came off
- -steves-
As this post covers pretty much everything in the world, I thought I would post these pictures up in here as well. The purpose as I said from day one was to always build a live steam loco from scratch. I have the following "kit" bits in the photos in the shed in a box and the intent "one day" is to have a go at building it. I figured I would start with 16mm as that's my garden railway and would be more useful
The box might be a little bigger than it looks?
To put it in scale better...
The box again
The box again
- -steves-
ytrhgf
- -steves-
Good to know they are well thought of. Yes that's the one, LBCS, I couldn't remember earlier
I am sure you will rectify and remake any parts necessaryOily Rag wrote: ↑Wed May 01, 2019 7:35 pm As the 25 quid. That was what my pal said it owed him. He had bid for those boxes of bits, some old Mamods and the like and those parts for the MINNIE just happend to be in the bottom of one of the boxes. A great find both for him and me. There have been many MINNIEs made and there is now even a set of drawings on the 'net for a metric version.
Some of the castings I have, have been badly machined but won't be too bad to hack out of solid. Its one of things like a good book, I can pick it up and put it down without any pressure as the mood takes. Really my next move with it is to make a jig suggested in the book to spoke up the wheels. I do want to change the design of the jig a bit to suit my methods of working but all will come out of scrap, offcut bits and a piece of 3/4" ply left over from topping out the workbenches.We too have had harder times financially so often making things was the only option. You know its fun! Really.And now I want to make everything, have a better garden (for the railway of course ahem) but that is not completely possible so my time is fuller than ever.
I too am in the process of doing the garden, I learnt to mix and lay concrete the other day, another skill added to the set, lol
- dewintondave
I think it's important to keep using the saws and files, otherwise the skills will drop off. I made a gas valve for an engine, lovely fine thread and fine taper, it was just like making a regulator. It's fitted to the 220g gas cylinder adaptor, I bought the hand wheel though
Best wishes,
Dave
Dave
I agree Dave...dewintondave wrote: ↑Thu May 02, 2019 8:11 am I think it's important to keep using the saws and files, otherwise the skills will drop off. I made a gas valve for an engine, lovely fine thread and fine taper, it was just like making a regulator. It's fitted to the 220g gas cylinder adaptor, I bought the hand wheel though
This thread is brilliant and the use of hand tools really does show off people skills, especially yours Steve..
The use of laser cut parts and CNC machining are very good especially if there is a long run to be done. I used to be CNC setter and operator and you just can't beat them for being accurate, but remember they are doing the work. Not a person, so when you hold something that has been made by someone rather than a machine, they do feel different. In my mind anyway....
The cylinder assembly looks good.
I often scratch a 'L' or an 'R' on parts that aren't obviously handed and when disassembling, put related bits in small labelled containers to keep them together. I also sometimes scratch a little arrow in an out of the way place to indicate the front when re-assembling.
Just had a look at the Wild Rose III drawings, looks like Dave Watkins assumed that builders would use commercial pipe fittings. The pipework G/A on drawing 19 shows the assembled fittings and the gas pipework drawing 21 shows the tails fitted on the piping, but I couldn't find dimensioned drawings.
I make my own, which is easy enough when you get set up for it.
The photo shows some bits for a 1/8" pipe fitting, which were all I could find. They may be commercial, as my supply of spares is in a 'safe' place somewhere. I make fittings with 1/4" x 40 ME nuts for 1/8" tube and 3/16" nuts for 3/32" and 1/16" tube and always make a couple extra in case I lose one under the bench.
I can't find my sketch cards either, so can't give you dimensions for a 3/32" pipe fitting.
The part on the left is designed to be silver soldered to the end of a pipe, so is a single union. The coned seat is drilled with a centre drill (slocombe drill) which gives the 60deg coned shape. Being an 1/8" fitting it is drilled 1/8" at the back, stopping short of the cone, so the fitting stays in the right place while silver soldering.
The 60deg cone on the tail is formed by laying the lathe topslide over at 30deg. Again drilled at 1/8" up to the cone, then through drilled at 3/32" so it stays in place when silver soldering. The body is turned down to clear the thread in the nut and the end is turned down further to provide the shoulder for the nut to engage when tightened.
The nut is threaded and then drilled to clear the end of the tail. There needs to be at least 1mm between the end of the thread and the back of the nut when it is parted off, or the olive will break through when the nut is tightened.
The parts for 3/32' are similar, just the thread is 3/16" x 40 ME and everything is proportionately smaller. I don't use 1/16" pipework much, but the fittings are the same as the 3/32" ones, except the tails are drilled 1/16" for soldering to the pipework.
Mine are copied from the 1/8" fittings that Roundhouse sell, but I don't think they use any 3/32" pipework. I can get single and double unions, tails and nuts down to 3/32" locally, so they will be available from ME suppliers in the UK. There are other designs around, but the coned tails seal more easily in my experience.
- -steves-
Hi Graeme
That's just what I was looking for.
This concerns me that the Wild Rose build sheets do not show a cone inside the bit that solders to the steam chests as I am not sure how you are supposed to seal that connection. I have started on the part on the last picture (shown in red), but just can't see how that is going to seal properly on the union suggested?? Any thoughts anyone?
Also I have had some time doing workshop stuff today which I firmly believe will assist dramatically in the project and other projects going forwards.
A DRO system for my mill, as I said before I fitted one to the Z axis to try out, it was that good I bought and fitted the other two axis today.
My original home build DRO built from a digital tyre depth gauge, a turned bit of brass, a couple of pen springs, a couple of washers, some magnets and some epoxy, but only good for about 25mm movement and as pain to see.
My new DRO system, all working great, so easy to read and set. Should prove useful going forwards. The bracket to hold them is a strip of ali, drilled and tapped to 3mm and bolted onto the motor mount from the belt conversion I put on the other month.
Last but not least, I am now set for learning to use a piercing saw, gave it a go on some steel sheet and brass sheet, sticks a bit in the brass and eventually broke the blade, good job I bought another 24 blades with it as I can see me going through them at a bit of a rate. Produces a very fine accurate cut, so I am a happy bunny, thanks guys
- Attachments
- steamfitttings1.jpg (187.99 KiB) Viewed 15483 times
- -steves-
Thanks for the compliment but I think the skills lay with others and I am merely "grasshopper", the student in training, lol Of course I try my best but sometimes the results end up in the bin, other times, well, they might pass, the time will tell when it comes to try to "fire it" up on air. With all the "bodges" and extra fettling I am doing I am not holding my breath. That said, they say the Wild Rose is good for a beginner, but I am thinking I would have been better off starting with an oscillator type engine like Brick or Idris, but hey, I guess that's just me, jump in the deep end and and give it a goFWLR wrote: ↑Thu May 02, 2019 9:36 amI agree Dave...dewintondave wrote: ↑Thu May 02, 2019 8:11 am I think it's important to keep using the saws and files, otherwise the skills will drop off. I made a gas valve for an engine, lovely fine thread and fine taper, it was just like making a regulator. It's fitted to the 220g gas cylinder adaptor, I bought the hand wheel though
Looks like it might be designed to seal with an o-ring, like the steam inlet tee on Roundhouse cylinders. (A fitting I dislike intensely.....)
If so, I'm not sure what size O-ring is intended to be used, as there's nothing on the drawing. A BS003 o-ring won't fit into a 3/16" ME nut which has a thread minor dia. of 5/32". By the time a BS003 o-ring is fitted over a 3/32" tube the od will about 7/32".
The only o-ring I have that might work with the fittings as drawn is a metric 4mm x 1mm size. With metric o-rings the first number is the od and the second one is the cross section and that's how you order them around here. In this case the hole in the doughnut works out to be 2mm dia., so it will be a tight fit with a 3/32" pipe in a 3/16" ME fitting and may take a fight to get into place.
I don't use o-rings for much except piston rings, gas valve glands and gauge glasses, so Ian or another builder may have a better suggestion.
- -steves-
Thanks GraemeGTB wrote: ↑Fri May 03, 2019 4:36 pmLooks like it might be designed to seal with an o-ring, like the steam inlet tee on Roundhouse cylinders. (A fitting I dislike intensely.....)
Do you know what tool you use for flaring the ends of the steam pipe so it doesn't pull through if it uses as an O-ring I assume you don't solder it to a union of some description?
Can anyone shed any light on this issue on the Wild Rose? The steam connectors seem a little confusing to me
- -steves-
If you have a look at the 16mm association website they have a section for downloads, then locomotives. Under that section is the wild rose drawings in PDF format. I think page 18, the steam fittings is the section I am struggling to work out how to deal that connection from the boiler to the steam chests. I have the steam chest one sussed, just that pipe that connects to it and goes off to the boiler.
No worries if you don't have time, it's just easier than me trying to explain it, lol.
Cheers
Steve
You don't flare the steam pipe, the design of joint shown relies on the friction from the compressed o-ring to stop the pipe sliding out, which I why I don't like them. In the case of the steam inlet tee on Roundhouse cylinders, once assembled the tee can't really go anywhere and I've never seen one move as both joints are at much the same pressure.
Flared fittings are used in plumbing and I've never seen any suitable for 3/32" copper tubing.
Looking at the pipe layout drawing #19, once the boiler is installed, there is very little clearance between the steam pipe and the bottom of the boiler at the front. So the pipe is blocked from popping out under pressure once the loco is fully assembled and running.
I've got a couple of the fittings described by Ian which I found in with my collection of boiler test adaptors, but I can't remember where they came from. I've also made a version with a spigot that fits into the hole in the union, which makes it easier to line things up when assembling, but couldn't find an example.
I've got a vague idea I made a few of this type before I worked out that a 60deg conical seat could be easily made with a centre drill and I then quickly standardised on coned pipe fittings for all steam and gas pipework. The one in the photo is 3/16" ME for 1/16" tubing, so may be a leftover from my Argyle Philadelphia loco rebuild, as that has 1/16" gas pipework.
- -steves-
Thanks Ian, I will have a look at what I think I will be able to make to work in there. I need to remake it anyway as I have drilled it all as 3mm instead of 3/32, my bad, I assumed this was the same thing until I looked it up and found out its nearer to 2.4mm. Live and learn
As for the bit I have quoted, I am afraid yet again I have no idea what you mean on this, what is the stem?
Cheers
Steve
- -steves-
I like the idea of what is in the picture, but being flat to flat I am not sure how well it would seal, but at least I could hard solder that flange on and be assured of it not pulling out. I may try and put a 60 degree cone on the connection and see what happens, after all it's only a little brass and time if it doesn't work, lolGTB wrote: ↑Sat May 04, 2019 11:47 am
- -steves-
Nope, still lost me I am afraid To me the valve is the slide valve in the steam chest which is open and closed by the eccentrics. Unless it's the bit the eccentric rod slides through into the steam chest? Sorry, total newbie to these term
Take your time, I am in no rush at all as I have ran out of material to do any more for a little while so it might be a few weeks before I can get things like the 1mm silver rod to join the eccentrics up etc. I do have enough brass to have a go at some of these unions and joints but as I say, absolutely no rush
English is such an interesting language, especially the engineering version.......
The type of valves Ian is talking about are the two versions of the gas control valve and the regulator valve. The stem is the bit labelled 'spindle' on the drawings.
As designed it is possible to screw the stem right out of the gas valve body, as the upper part of the stem is the same dia as the threaded part. If the gas tank is full, the pressure will push the stem through the gland as soon as the thread disengages. Frostbite on the finger tips from the escaping gas might be the least of your worries if there is an ignition source in the vicinity.
To prevent the stem of a valve being easily removed it is usual to reduce the diameter of the stem above the threaded part and reduce the size of the hole in the gland nut to match. The gland nut and the stem thread are different in pitch already and will lock if turned at the same time, so with the reduction in stem dia., the only way to remove the stem is to remove the gland nut first.
In case you are wondering, the gland is the seal around the stem that stops anything leaking out of the valve past the stem thread. In the gas valves it's a piece of teflon tape, or silicone tube, wrapped around the stem and compressed by the nut. In the regulator it's meant to be an o-ring.
If you look at the regulator drawing (which is technically a needle valve like the gas valves) on sheet 16, you will see that it is drawn this way and the stem can't be screwed out without removing the gland nut. The upper part of the stem is 2.2mm dia, but the thread on the stem is 6BA (2.7mm) and there is a 2.3mm hole in the 3/16" x 40 ME gland nut. So the regulator valve stem won't come right out if a driver turns it too far for some reason.
I see the gas and regulator valve stems call up stainless steel. I which case you will need HSS dies to cut the threads. Carbon steel dies will go blunt very quickly when threading stainless. There's no reason why the valves should have different threads either. M3 and 6BA are equivalent, just pick one and save the cost of a die.......
Returning to the pipe fittings, you are right, the flat seats are harder to seal. Which is why I always use coned fittings now.
- -steves-
Been a bit quiet on this as I got a tad disheartened with it as when I tried to run it on air a few weeks ago I failed miserably. I tried to time it etc etc etc many times with no success. Kinda gave up for a while and left it on a back burner, but also to be fair, there has been a ton of other things on recently including many a BBQ and a small open day for family and a couple of friends, days out here and there.
Well, today I tried again, it still isn't right, far from it, however a small step forwards as it eventually ran air. I would suggest turning the sound off as the compressor is very noisy, however if you like loud noises and decide to leave the sound on, you may also hear a clunking noise coming from the engine, not sure what this is as yet but I have not sat down and looked yet either. I had it all running as smooth as silk at one point this morning, but since putting it back together it has a few tight spots again, arghhh! Still smiling though as it's so amazing to see something you have cobbled together out of blocks of metal suddenly spring into some sort of life and take flight, well sort of, it turned the wheels
It sounds and looks ok to me Steve...But then again I haven't got my earphones in at the moment...
Could you fit an air supply direct to it. You could then hear it better and it may round smoother. It may not, but no harm in trying is there.
I've found it pays to walk away if things aren't going right. While you mull it over in the back of your mind, eventually the answer comes to you........-steves- wrote: ↑Wed May 29, 2019 3:27 pm you may also hear a clunking noise coming from the engine, not sure what this is as yet but I have not sat down and looked yet either. I had it all running as smooth as silk at one point this morning, but since putting it back together it has a few tight spots again,
Well done, you must have made the parts properly, or it would never have worked. If it has run well once, then it can be made to run again.
Does the chassis turn over smoothly by hand when not connected to the compressor? If not, you may have reversed a wheelset, or swapped rods when reassembling things. It shouldn't make a difference, but sometimes the tolerances add up the wrong way and some parts have only one orientation where everything works smoothly.
If the wheels and rods aren't binding, then it may be the valve timing that is out. With these little locos, the valves should be set line for line. Unlike larger scale and full size locos, any advance will make them run lumpy, as they don't have the weight and therefore momentum to compress the steam (or air) if the valve opens early, before the crankpin is at dead centre.
Also check that the piston rods are pushed into the crossheads far enough and aren't hitting a cylinder end cover. Been there.....
I've never built a slip eccentric loco, but FWIW my valve setting procedure should work.
- Centre the slide valve first, by adjusting the valve position on the valve rod so the valve openings are the same at each end, in both forward and reverse, or as near as you can get them. At this point it doesn't matter exactly where the eccentric is set.
- Only adjust the timing by adjusting the eccentric (or the stop collar in the case of slip eccentrics) once the valve has been centred. The valve should be just starting to open as the crankpin is at dead centre at both ends of the piston stroke.
- Once one side is timed, then repeat on the other side.
I use oiled brown paper gaskets for steam chest joints, as the gaskets don't have to be replaced each time the valve chest is opened while setting up valve gear.
