DLRdan
Post
by DLRdan » Tue Dec 30, 2008 6:22 pm
I have always liked dewinton style locos but have always looked at most models with a slight disapointment. Most of the ones i have seen are always oversize and have lost the charm of the originals. So I set out to build a scale model of an original. The actual loco was finished in a month and has taken about 5 months to get it to nearly work, the hazards of building something this small. I will put some pictures in once I do some
ACLR
Post
by ACLR » Tue Dec 30, 2008 7:53 pm
looking forward to seeing the pics of it
DLRdan
Post
by DLRdan » Tue Dec 30, 2008 9:52 pm
A pcture as promised. This was taken a while back and hasnt got some oof the latter refinements on. It has ahd a new boiler fitted today with a bigger flue which should help air circulation, but hasnt got a chimney yet.
ACLR
Post
by ACLR » Wed Dec 31, 2008 3:49 am
nice
DLRdan
Post
by DLRdan » Fri Jan 02, 2009 9:25 pm
update time. A new boielr with a larger flue has been made and it raises steam quite happily now and even ran all be it slowly. This morning dad made a new chimney( cos hes like that) and after putting it on, the engine runs quite well now and even ran on the track for the first time in weeks. Expect a video in the next few days
pauly
Post
by pauly » Mon Jan 12, 2009 9:06 pm
away then wheres that video?
A steam propelled life-style.
DLRdan
Post
by DLRdan » Mon Jan 12, 2009 9:53 pm
pauly
Post
by pauly » Mon Jan 12, 2009 10:31 pm
seems to be really struggling
have you considered fitting a wilesco cylinder instead of that ossy cylinder?
will probably give more power
DLRdan
Post
by DLRdan » Mon Jan 12, 2009 10:46 pm
think its just strugeling because of the uneven floor boards. you cant see it in the vid but the floor is all over the place
DLRdan
Post
by DLRdan » Mon Feb 16, 2009 6:16 pm
Its that time again folks. As you saw in the last (badly edited) video, Falcon was nearly running but not really. So after a little more fiddling i ended up with this, and yes it does pop and bang (barks too)
<embed width="448" height="361" type="application/x-shockwave-flash" wmode="transparent" src="
http://i273.photobucket.com/player.swf? ... 1_0734.flv">
SillyBilly
Post
by SillyBilly » Mon Feb 16, 2009 6:22 pm
That's really good to see Dan, I'm hoping for a heat wave this summer because then you can make a video of it doing a circuit!
made-in-england
Post
by made-in-england » Mon Feb 16, 2009 6:52 pm
Looks great!
pauly
Post
by pauly » Mon Feb 16, 2009 8:38 pm
urr why is there a DR pepper can wrapped around the boiler
pauly
Post
by pauly » Mon Feb 16, 2009 8:39 pm
oh and whats that loco in the background pulling the wagons?
DLRdan
Post
by DLRdan » Tue Feb 17, 2009 9:43 am
the can is there to keep the lagging on. I had to lag the boiler as there was just too much heat being lost from the sides, and makes a huge difference. The little loco is one i made from bits nothing special but runs well
