The original is 3'6" guage so it would probably have been better suited to 45mm but I want to build a 32mm line so 2' guage it is.
Still a bit to do, mainly trim and filler around the roof, seating inside, and new radiator grille more in keeping with the AEC original. The one tacked on the front here is a first attempt!
I'm anticipating possible stability problems and may need to retro fit some kind of compensation/springing to stop it lurching from side to side or listing to one side or t'other. However I only have an oval of Mamod track to test it on and haven't had chance to set this up since my first test of the running chassis.
There is a sliding door to be fitted on the rear panel to access a trailer car but not sure if I will build one. The rear light flashes red.
Im trying to bury as much of the messy wiring under the floor as I can. Seats are still to be fitted. A couple are shown in position. It should seat 10/12 plus driver who will have a bucket seat.
