cncmodeller
Post
by cncmodeller » Thu Sep 12, 2013 8:38 am
A couple of in progress shots of my Accucraft Superior which I am detailing as near as possible to how she looked in Bowater days, The loco has received a new cab front sheet to correctly position the cab front spectacle plates, Cab side sliding window rails and associated rivets, the dome housing painted black, I would love to shorten this but where do you get a shorter safety valve from? New riveted buffer beams and new paint job. Things still to do are the scale buffer/coupler housing, etched name and works plates and lining out.
Post
by Narrow Minded » Thu Sep 12, 2013 8:47 am
Nice work so far! - in fact a huge leap from the more "generic look" of the as-supplied loco
Have you thought about shortening the SV rather than trying to find a replacement? Without looking at reference photo's to see how much you need to lose, it might well be possible.
Looking forward to further progress.
steamie1
Post
by steamie1 » Thu Sep 12, 2013 9:27 am
Looks so much better, keep going..
Post
by tom_tom_go » Thu Sep 12, 2013 9:36 am
Good stuff.
Spray painting the smoke box and cab roof with heat resistant stove/BBQ paint will make a big difference to that loco
LnBmad
Post
by LnBmad » Thu Sep 12, 2013 9:52 am
Great looking model! The additions really do enhance the looks. A Tom said I'd be tempted to go with a matte black on the cab roof and smoke box, this could be done using a matte lacquer though.
As for the safety valve how much shorter does it need to be?
Are there any other details your planning to add in the future?
Post
by Andrew » Thu Sep 12, 2013 11:19 am
That looks great!
Did you mask and spray the black edging? Must do it to my RH Russell sometime but have been considering brush painting the edging...
Glad you haven't aded those huge couplings Bowaters used...
SapperAnt
Post
by SapperAnt » Thu Sep 12, 2013 2:41 pm
Looks stunning!!!!!!!!
Post
by Chris Cairns » Thu Sep 12, 2013 2:51 pm
That is some very appropriate customisation.
paullad1984
Post
by paullad1984 » Thu Sep 12, 2013 3:05 pm
Now if only Accucraft would rerelease the model to that standard!
cncmodeller
Post
by cncmodeller » Thu Sep 12, 2013 5:59 pm
tom_tom_go:88385 wrote:Good stuff.
Yes that is another job on the list, although I do plan to remake the smokebox as its incorrect dimensionally. The smokebox door is too large and the length of the smokebox itself is too short.
cncmodeller
Post
by cncmodeller » Thu Sep 12, 2013 6:02 pm
Andrew:88394 wrote:That looks great!
Yes I did mask and spray the black edging by cutting masking tape out on a Laser cutter, I did the yellow lining on the buffer the same way but it's not as good as a lining pen, so I'm going to Laser out thin Perspex templates that will be mounted off the green areas and this will act as a shoulder for the pen. I've done this before with triple lining and it works a treat.
cncmodeller
Post
by cncmodeller » Thu Sep 12, 2013 6:08 pm
LnBmad:88388 wrote:Great looking model! The additions really do enhance the looks. A Tom said I'd be tempted to go with a matte black on the cab roof and smoke box, this could be done using a matte lacquer though.
Thanks for your kind comments, I think the safety valve needs to be half its height, which I'm not going to mess with due to safety concerns. I would like to add a spotlight on the smokebox which is more like a 1960/70's car fog lamp, Haven't found one yet so may CNC one up. I'm also after another Superior as I would like to Convert it to a Bagnall, as 'Alpha', 'Triumph' and 'Superb' were copies using the same Kerr Stuart design chassis but with Bagnall styled superstructure.
paullad1984
Post
by paullad1984 » Thu Sep 12, 2013 6:19 pm
Wonder if a Joan boiler would be better off for doing a bagnall?
90733
Post
by 90733 » Thu Sep 12, 2013 6:29 pm
Very nice work.
Thanks
Jack
cncmodeller
Post
by cncmodeller » Fri Sep 13, 2013 9:52 am
paullad1984:88420 wrote:Wonder if a Joan boiler would be better off for doing a bagnall?
I thought that but the safety valve is still at the back on the Bagnalls and Joan's is in the dome.
paullad1984
Post
by paullad1984 » Fri Sep 13, 2013 10:39 am
i was thinking more for the positioning of the sand boxes on the boiler, there being fixings allready
DolwyddelanLightRail
Post
by DolwyddelanLightRail » Fri Sep 13, 2013 11:16 am
Very nice work!
Paul H
Post
by Paul H » Fri Sep 13, 2013 7:47 pm
Nice work! I use miniature pop valves made here in the U.S. by WeeBee Loco Parts. They are much smaller than Accucraft and Roundhouse valves and open and close with a snap. PM me for the maker's email address if interested.
Paul
Endless, Nameless
Post
by Endless, Nameless » Sun Sep 15, 2013 9:47 pm
Can't help with the safety valves, but that looks lovely
Dr. Bond of the DVLR
- Retired Director
Post
by Dr. Bond of the DVLR » Sun Sep 15, 2013 9:57 pm
How did I miss this?
Lovely work!
