The new guy: Coal fires locomotive boiler build :)
Cameron
Post by Cameron » Wed Apr 25, 2012 3:32 pm
Hey all, I've been a member here for sometime but have never had anything to post as most of my live steam was stationary and I often buy, repair/modify and resell.  However, I have finally decided it is time to put some time and money into a proper engine, or at this stage a boiler. I am a member on a few other forums (so you may have already seen this) but having seen all the wonderful posts on this forum I felt I should share what I am up to :)
I am building a coal fired locomotive boiler - not for any particular engine but it is of similar size (I believe) to the DJB engineering coal boilers for Accucraft (correct me if I am wrong, I always (forget) so maybe at some stage I will look into those or pass this boiler on to someone. Anyway here is my progress:
A week (maybe two, I'm so busy I can hardly tell anymore) ago I received this in the mail:
http://www.flickr.com/photos/64640917@N05/6946382100/
From here I proceeded to make my moulds
http://www.flickr.com/photos/64640917@N05/6949621610/
Unfortunately I did not photograph any of the boiler shell while being annealed but this photo gives an idea of what happens
http://www.flickr.com/photos/64640917@N05/7112348329/
http://www.flickr.com/photos/64640917@N05/6966272794/
http://www.flickr.com/photos/64640917@N05/7112349893/
The two boiler case: the one with the higher hole will be attached to the boiler barrel and the lower hole is for the fire box door.
http://www.flickr.com/photos/64640917@N05/7112346971/
I used some very fine sandpaper P600-1200 to bring the metal up and then drilled the holes for the five fire tubes:
http://www.flickr.com/photos/64640917@N05/7112345085/
http://www.flickr.com/photos/64640917@N05/6966269244/
And this is where I left it this evening
http://www.flickr.com/photos/64640917@N05/6966267288/
I couldn't make the photos work, so I have been forced to leave links. Usually the BBCode would work, but I've never posted photos here  :roll:
Cheers guys,
Cameron
Keith S
Post by Keith S » Tue May 01, 2012 11:42 pm
I mean to make one of these boilers myself one day. I'm looking forward to seeing how you get on.
