Wild Rose build
andysleigh
Wild Rose build
Post by andysleigh » Sun Apr 15, 2012 2:24 am
I thought i would have a go at building Dave Watkins's Wild Rose from scraps of material i have.
This is how far iv got since monday
Post by -steves- » Sun Apr 15, 2012 7:42 am
Looks good so far, really looking forward to seeing how this one goes, keep us updated :D
Dr. Bond of the DVLR
Post by Dr. Bond of the DVLR » Sun Apr 15, 2012 9:51 am
Oh wow, that looks grand!
DaveWatkins
Post by DaveWatkins » Sun Apr 15, 2012 11:07 am
that is looking good.
Dave
gauge
Post by gauge » Sun Apr 15, 2012 1:57 pm
Hi Andy, Im scratch building my loco,A kerr stuart brazil, As im just getting into 16mm gauge,Can you tell me who Dave Watkins's is and what is Wild Rose, I assume he suppys drgs :| Thankyou Gauge nice work by the way :D
DaveWatkins
Post by DaveWatkins » Sun Apr 15, 2012 4:05 pm
I had better chip in here. I built the original Wild Rose based on the small quarry Hunslet locomotives used in the North Wales slate quarries. Keith Bucklitch described how to build one, Wild Rose Too, in SMT back in 1987 or thereabouts. He actually built two locos, an open cab and a closed cab version.
For a few photos and the list of relevant SMT issues see:-
http://www.davewatkins.pwp.blueyonder.c ... /steam.htm
I am currently working on revised drawings but have not as yet built a loco form these new drawings. So far I have redrawn most of the working parts including a meths burner. I am currently at the stage of designing gas tank and burner for a gas fired version. The bodywork is to follow. See:-
http://www.wildrose16mm.blogspot.co.uk/
The draft new drawings are at:-
http://www.davewatkins.pwp.blueyonder.c ... wings.html
Dave Watkins
andysleigh
Post by andysleigh » Sun Apr 15, 2012 7:04 pm
Thanks chaps.
Dave,  i dont suppose there are any imperial drawings for the tank.
i think the article from which i am working just says to doing it from an end view of a hunslet.
It would be interesting to do a proper loco boiler like TME do, but i think thats out of my leque!
DaveWatkins
Post by DaveWatkins » Sun Apr 15, 2012 10:14 pm
Sorry I don't have a drawing in Imperial.
This might be helpful. It is the sketch I did for the tank and burner I used in a model of Bagnall Sealion. The tank sits on the footplate. I resited the gas take off and control valve to the top of the tank rather than on the side as shewn. Not shewn are the slits in the burner tube - around ten slits needed - should be in the first half of the burner tube staring from the gas jet end.
Click to download file
Another drawing that may be helpful, this time for a tank below the footplate is the one I made for Bagnall Brick:-
http://www.davewatkins.pwp.blueyonder.c ... burner.pdf
[/img]
andysleigh
Post by andysleigh » Mon Apr 16, 2012 4:35 am
I ment the saddle tank ;)
but thanks for the info anyway. its all helpful.
gauge
Post by gauge » Mon Apr 16, 2012 5:09 pm
Thanks for the info Dave,Im building Keiths Loco,as i wanted a garden railway and did not have a grand for a loco,But engineering is easy for me cuz ive been doing it for a living for 30 odd years :) So if all goes well ill be doing the Wild Rose next, And Andy Really mate do not be frightened to build a boiler, if you can do engineering like the stuff you have shown you can build a boiler you do need a good size torch to get the heat, you get enough heat for the solder to melt , and the copper is good and clean, you can not go far wrong, ive built several in 5 inch gauge and 16mm ones are a doddle, if you need help just ask ill be only to pleased to guild you throu it :) all the best Gauge
andysleigh
Post by andysleigh » Tue Apr 17, 2012 12:44 am
gauge:69804 wrote: And Andy Really mate do not be frightened to build a boiler, if you can do engineering like the stuff you have shown  you can build a boiler you do need a good size torch to get the heat, you get enough heat for the solder to melt , and the copper is good and clean, you can not go far wrong, ive built several in 5 inch gauge and 16mm ones are a doddle, if you need help just ask ill be only to pleased to guild you throu it :) all the best Gauge
i have never done that kind of soldering job before. but would like to elarn, as contracting someone els to build one is expensive.
The pot boiler or internal gas boiler doesnt put me off to much.
I was refering to designing a proper loco boiler, with a wet firebox,
designing and making that style boiler, that small wouldnt be the ideal start project.
thanks for the postivie words :D
Cann
Post by Cann » Mon May 07, 2012 3:56 pm
Hi andy any more news on the wild rose?
I started one a couple of years back as a first build. I got stuck with the cylinders and put it away.
andysleigh
Post by andysleigh » Mon May 07, 2012 9:17 pm
Cann:70582 wrote:Hi andy any more news on the wild rose?
Hi Richard
Noting since the pics above.
I have been concentrating on my coal fired edrig, which i was stuck on and put away for a few years.
Nicolas
Post by Nicolas » Sun Dec 15, 2013 12:23 am
Hello Andy,
Did this project ever get finished?
I am interested in building the wild rose and it would be great if I could find a build thread on it, are there any other build threads of this loco that I could find here?
Thank you for your help,
Nicolas
andysleigh
Post by andysleigh » Sun Dec 15, 2013 12:26 am
Nicolas:93636 wrote:Hello Andy,
Nicolas
Hi Nicolas
i never got any further than what you see on here!
bigger locos took priority eventually.
andy
Nicolas
Post by Nicolas » Sun Dec 15, 2013 12:29 am
Thanks for the quick reply,
Do you know of anybody else who has built the loco?
Thanks,
Nicolas
andysleigh
Post by andysleigh » Sun Dec 15, 2013 12:31 am
Im afraid i dont, apart form the designer Dave Watkins, whos on here.
or at least used to be on here.
Nicolas
Post by Nicolas » Sun Dec 15, 2013 12:33 am
Thanks,
I have heard about a "wild rose too" but I have found nothing about it, do you know about it? or someone else who might?
Nicolas
Post by GTB » Sun Dec 15, 2013 8:13 am
Nicolas:93641 wrote:Thanks,
Dave Watkins has updated his original Wild Rose design fairly recently, named Wild Rose III. Wild Rose Too is Keith Bucklitch's version of Wild Rose, written up in SMT magazine years ago.
Dave generously shares his work on the net and the drawings and a construction Blog for Wild Rose III are available online here
and here
http://wildrose16mm.blogspot.com.au
There are other examples of Dave's work on his website at
Nicolas
Post by Nicolas » Sun Dec 15, 2013 8:55 am
Thanks for the info Graeme :D
Nicolas
