DLRdan
Post
by DLRdan » Sun Mar 18, 2012 8:20 pm
williamfj
Post
by williamfj » Sun Mar 18, 2012 8:36 pm
Looks very good!
dougrail
Post
by dougrail » Sun Mar 18, 2012 10:01 pm
Lovely little engine mate - do I detect some frame adjustments?
Sir haydn
Post
by Sir haydn » Sun Mar 18, 2012 10:35 pm
Dan, that is genious. The bunker looks like it should be there, The flat cab backs on mamods will look odd now
Post
by Narrow Minded » Sun Mar 18, 2012 11:58 pm
Very neat!
spooner
Post
by spooner » Mon Mar 19, 2012 10:01 am
If it gos as well as it look your on a winner.
DolwyddelanLightRail
Post
by DolwyddelanLightRail » Mon Mar 19, 2012 12:28 pm
spooner:68130 wrote:If it gos as well as it look your on a winner.
All of Dan's locos go very very well! On about 0.5ml of meths per hour as well
Liking the coal bunker as well!
laurence703
Post
by laurence703 » Mon Mar 19, 2012 3:38 pm
Very nice! I like the coal bunker idea! It looks much better than the glued on wedge that looks like it shouldn't be there... I had pondered about the wedge before I opted to make use of my tender...
DLRdan
Post
by DLRdan » Mon Mar 19, 2012 10:21 pm
Thanks guys
The frames haven't been altered at all, I moved the rear drag beam back and made some extentions for the buffers.
Spule 4
Post
by Spule 4 » Tue Mar 20, 2012 1:38 am
Very nice, agreed as others on the bunker, but my interest is the bufferbeams. Did you make those yourself with the rivets?
DLRdan
Post
by DLRdan » Tue Mar 20, 2012 10:09 am
I did make them myself, brass sheet with holes drilled then copper rivets soldered in.
Post
by -steves- » Tue Mar 20, 2012 10:36 am
Would love to see some pictures of how you did that cab extension and moved the buffer beam back
looks awesome
DLRdan
Post
by DLRdan » Wed Mar 21, 2012 11:57 pm
Here you go Steve. Its reasonably simple, the brass pieces are for the buffers as I didn't want to try making the bolt longer. The bunker itself just bolts on using the handrail holes. If you want a look in person I can bring it down to peterborough.
Spule 4
Post
by Spule 4 » Thu Mar 22, 2012 12:48 am
Interesting way of extending the rear bufferbeam.
I got some spare tanks and cab front from eBay for modifying my Mamod. Unfortunately, the previous owner cut the rear tabs on the back of the tanks where the buffers were to bolt on?
Pendo Pilot
Post
by Pendo Pilot » Thu Mar 22, 2012 1:35 am
That does indeed look superb. At this rate I may have to send you a box of mamod for fettling!
dougrail
Post
by dougrail » Thu Mar 22, 2012 8:51 am
so simply, two bars and longer screws is all it takes?
Post
by -steves- » Thu Mar 22, 2012 9:34 am
DLRdan:68216 wrote:Here you go Steve. Its reasonably simple, the brass pieces are for the buffers as I didn't want to try making the bolt longer. The bunker itself just bolts on using the handrail holes. If you want a look in person I can bring it down to peterborough.
I am with the buffer extenders, great idea, I can easily knock some of those up in the lathe
I think where I would struggle is with the meths burner which is a "Gremlin" special and looks like it would have issues screwing the retaining bolt up as the burner will not move back with the buffer beam. I think I will have to make a new part to slide in there so the whole buffer beam doesn't move back, just the buffer and a "fake" buffer beam. Either that, or how did you over come the attaching the burner again? What burner are you using?
DLRdan
Post
by DLRdan » Thu Mar 22, 2012 11:40 am
Im using a vaporising type burner I made, so I could just drill another hole in the burner bracket.
Post
by -steves- » Thu Mar 22, 2012 12:02 pm
DLRdan:68234 wrote:Im using a vaporising type burner I made, so I could just drill another hole in the burner bracket.
it would seem an ingenious plan will be needed, lol
Looks great, can't beleive what a difference it has made from a standard one
