New quarry engine
New quarry engine
With no line to run, my stock building is key focus - I should really be just building wagons to build up the number I have BUT I do like a loco - so I’ve had a go at a Phil Sharples mini Jack kit - it just needs the electrics fitting and ready to go - including real crushed coal!
- Attachments
- 08203E52-FA3E-4D37-9C79-5C67176BA3CE.jpeg (172 KiB) Viewed 8367 times
Re: New quarry engine
Nice one, Mark. Reminds me (sort of) of the Guinness Brewery engines.
Indoor shunting layout required for that loco
Using Deltang that could run R/C as well.
A very handsome loco with some very nice details,And most of all not to expensive, Must get on to finish some of my projects!
Agree with Tom, put it on an indoor line. It would look great pulling some beer barrels....
Yes - its funny you should say that! If we end up renting, that's the route I'm going down as a temp measure - Tony Hill's (now sold ) Melin Llechi is an inspiration - I have wondered about starting some of the boards for the fabled garage section of CHLR mk2tom_tom_go wrote: ↑Sun May 26, 2019 9:42 am Indoor shunting layout required for that loco
And yes, will make sure its 'deltangable' - there is a discussion on F/B at the mo about making a plug in and out receiver unit so we can swap between locos easily - Phil at RC is involved via his Mrs
Now I have remembered my username (and reset my password) on here... Again! ;-}
I will try to drop in more often..
(Phil of RC Trains..)
<Aside>
Tom, is there a way to get 'newest posts' to appear as top of the queue, at index level? - I tend to eventually read everything, but it is nice to see the most recent postings first.
<thread-drift-OFF>
<Aside>
<thread-drift-OFF>
When you login click or tap 'notifications', this lists all the latest posts in order.
Also:
https://gardenrails.org/forum/viewtopic ... 33&t=11217
Also:
Now fitted with Deltang and has been running on the temp line - video to follow - can crawl VERY slowly
That's really, really nice!
Thanks guys - it’s taken a while to get it balanced weight wise but it is now running sweet - as you say Tom a great shunting engine for a few sidings - a bit under powered for the main line
