Coal Fired Steamer "Earl of Pentland"
Answering Keith's questions regarding the engine in my steamer.
Although the engine has different sized cylinders, it actually runs as a simple because Compounds are not reliable self starters without a Simpling valve. I actually cobbled two engines together, one 5/8ths.x 5/8ths. and one 1"x 1" which made for an interesting crankshaft, in order to get a self starting engine. Unfortunately most of the crew jump ship when it leaves the wharf so it runs a little short handed (4 channels)
The boiler is a pot type with water tubes, built and inspected under the code and sitting in an insulated steel shell, hence the rust. I tried to make the boiler and engine rooms appear more prototypical by including floor plates and laying them out according to accepted practice. To this end there is a two stage condenser, engine driven feed pump, and a separate donkey feed pump on the port side. Sounds good sitting at the wharf with the feed pump ticking over (weasing Weir's they were usually called)
It is fun to operate, although hard on the old back firing and tending to the auxiliaries. The boiler is naturally drafted with the high funnel (no suction fan required)and makes an abundance of steam, and smoke (smoke being the reason behind the whole thing)
Grant, I'm not a ship person at all, but you have created such a magnificent boat there I can only admire your skill as an engineer and as a craftsman to produce a beautiful working model.
I bet it creates quite a stir with the viewers when you operate it?
Jim, general view under "Projects" "Vessels" below three shots in the engine room. There's not a lot of room in there for a camera. First shot shows the donkey pump and lubricator to port.
Next main engine, or part of it.
Finally both stages of the condenser and main lubricator on the starboard side. I don't re-use water from the condenser as it's still a bit oily, so it goes over the side.
And if i did show you the greasy innards that would be the bilges, but we won't go there. Gamlin (Navy bilge cleaner) keeps that in check.
- Dannypenguin
Wonderful piece of engineering
Dan
