Just made a little video showing how Deltang receivers can be reprogrammed using a Deltang Tx20.
https://www.youtube.com/watch?v=RIQzRCFTK2M
The same approach works with any Spektrum DSM2 transmitter - see the Deltang video - https://youtu.be/nbNrcFNTFZY
Reprogramming Deltang receivers
I think the greatest hurdle is the first one - deciding what you want the receiver to do and then working out which setting on the chart will make that change. Once you've got that information, the actual programming is relatively straightforward.philipy:114074 wrote:Thanks once again Rik. Looks simple when you know how!
- -steves-
I would definitely agree with thatge_rik:114080 wrote:I think the greatest hurdle is the first one - deciding what you want the receiver to do and then working out which setting on the chart will make that change. Once you've got that information, the actual programming is relatively straightforward.philipy:114074 wrote:Thanks once again Rik. Looks simple when you know how!
