The Westwood & Loscoe Light Railway
Post by Narrow Minded » Wed Aug 07, 2013 6:20 pm
hussra:86646 wrote:Oooh, I like the bridge - is that new? (Tuxcraft?)
Thanks Richard :D, it's not new - it used to be down the bottom end of the garden and had become very overgrown with ivy, plus the "trees" either side of it more-or-less hid it from view so I decided to move it.
It now forms a nice scenic break hiding the garden path, and provides a logical access to the cattle pens.
It's actually a cast concrete garden "ornament" ;)
Post by Chris Cairns » Wed Aug 07, 2013 6:33 pm
Looks like the cattle are very happy with their 'new' bridge.
Dr. Bond of the DVLR
Post by Dr. Bond of the DVLR » Wed Aug 07, 2013 6:48 pm
Good to have you back, looks very well integrated allready!
Post by laalratty » Wed Aug 07, 2013 8:51 pm
Very nice, not many people go to the effort of modelling over bridges, but they do usually reward the effort put in. Of course, for fun you could try putting the cows on the track, and I can guarantee that it will be entirely prototypical....!*
*Yes, we did have a herd of cows escape onto the track at Ravenglass last week :roll:
Post by Andrew » Thu Aug 08, 2013 11:30 am
Very nice - I'd be tempted to add a white square on the bridge behind the signal to aid drivers sighting it as they hurtle along at, err, 15mph... OK, not very narrow gauge, but I'd still be tempted. I like it when you see the ghostly remains of those squares long after the signal has gone...
Post by Narrow Minded » Fri Aug 09, 2013 5:48 pm
Whoo-hoo! 1,000th post on this thread :D and to celebrate, it just happens to be about the re-instatement of one of my personal favourite scenic features! ;)
When I re-modelled Codnor station,
I had to remove the old crossing to clear the site. It used to look like this;
and I've really missed it as a "photo location" since it was gone :cry:
So, as of today, it's back!! :occasion9:
No "crossing hut" this time, but of course, it's controlled from the 'box :D
Lner fan Sam
Post by Lner fan Sam » Fri Aug 09, 2013 6:03 pm
Very nice. :D
Sir haydn
Post by Sir haydn » Fri Aug 09, 2013 8:43 pm
Brilliant! always loved your level crossing. Glad its back
Post by Peter Butler » Fri Aug 09, 2013 10:32 pm
All looking very nice....
You might have been asked before but: Where do you get your metal fencing from?
Post by Narrow Minded » Fri Aug 09, 2013 11:55 pm
The fencing is off-cuts from "Harris Fencing" (the panels seen on building sites etc), Fire Guards and Pet cages - (all "recycled" from our local tip ;) )
Post by Narrow Minded » Fri Aug 23, 2013 9:09 pm
Thanks Dan! - the modded dome fits a treat  :thumbleft:
and the filler now sits here....
Post by Chris Cairns » Fri Aug 23, 2013 9:42 pm
Interesting Greg.
I assume you have made the swap as you did not like the look of the safety valve sitting above the cab front plate. On the original IP Eng combination that did not occur but Dream Steam have changed the size of the components used.
I recall getting involved in a discussion way back where someone asked if swapping the safety valve & water top up valve positions would cause problems. One thought was with the boiler under pressure some of the water injected could end up in the regulator tube or go down the sight glass tube to give a false reading.
Be interesting to hear your experiences with this altered set-up when you get your 'permission' to steam again.
Post by Narrow Minded » Tue Aug 27, 2013 6:59 pm
Not long now Chris, and I'll certainly let you know - BTW, you're quite right. I made the swap because I think it improves the look, but also removes the slight hassle of having to remove the dome each time I topped-up the water level (and yes - it got HOT! ;) )
Now,
Convalescing
present participle of con·va·lesce
Verb
Recover one's health and strength over a period of time after an illness or operation.
Obviously on "doctors orders", but I've managed to tackle a few projects over the last couple of days ;)
First off some scenics - I fancied one of those disused WW2 pill-boxes that used to guard strategic locations around the countryside, so rather than splash out 20 quid for one of the excellent Cain Howley cast concrete versions, I carved one out of a spare thermalite block :D
Here it is with the new low relief warehouse I've knocked up out of an off-cut of shuttering ply covered with corrugated sheet to save another 55 quid on the far superior Model Town resin cast one ;)
Next, rolling stock - I've wanted a little "quarry coach" for some time, and been very tempted by the workers coach recently released by Andel, but I've also been swayed by something along the lines of Lord Penrhyn's private coach.
At the end of the day, I just wanted something small and different to add to my quarry stock so being a tight-bottom, I've resurrected an old IP Ezee passenger coach which has spent the last two years living out in the garden as a grounded coach body and raided the "bits box"!
Here's the Waingroves Quarry owners coach -
complete with old Lord Punrhyme and his "secretary/nurse/assistant" 8)
My own "secretary/nurse/assistant" tells me that I'm not allowed to attend the Llanfair gathering this weekend :cry:
but if I'm a good boy, I can have a steam up at home! :D
Johnnie2sheds
Post by Johnnie2sheds » Tue Aug 27, 2013 7:15 pm
Good to see you up and about Greg. I guess you'll have to convert one of your buildings into a tanning salon?
hmmm call it "sun your buns"? 8)
Post by Narrow Minded » Tue Aug 27, 2013 7:21 pm
Johnnie2sheds:87387 wrote:Good to see you up and about Greg. I guess you'll have to convert one of your buildings into a tanning salon?
I think she uses a sunbed at the "Curl-Up & Dye" hair salon in Westwood:lol:
Big Al
Post by Big Al » Tue Aug 27, 2013 8:05 pm
Magic bit of modelling, I like the WW2 Pill box :D
Sir haydn
Post by Sir haydn » Tue Aug 27, 2013 9:55 pm
Some excellent modelling yet again greg! Glad your feeling more yourself!
Post by Narrow Minded » Wed Aug 28, 2013 9:33 pm
Feeling much better ta ;)
So much so that I was "allowed out" again today, so I can show you where Lord Punrhyme's coach normally lives........
At the back of Waingroves Quarry shed! :D
After hinting that I felt well enough for a little steam-up, my carer agreed just so long as I didn't have my head down for too long.
"Single fill, radio control" thought I, so it was a case of ~ Prepare The Earl!
Fancy a trip along the Westwood & Loscoe? - I haven't posted one for a while, so here goes.......
The signalman at Robin Square checks his watch
as The Earl takes the loop to join the head of the 11:30 Up Mixed,
before waiting for the Down train heading to Bagthorpe Colliery.
After the right away, we catch a photo opportunity through The Alley,
and again at Golden Valley Halt,
Riddings,
Codnor Wood,
and make good time passing Codnor Castle signal box.
where a mixed rake of quarry empties wait for the road.
finally arriving on time at Loscoe just as the livestock pens are filling up (well, it's wednesday, so it is market day!).
While we're at Loscoe, we see Blodwen arrive with the 14:00 mixed.
Then, after having a liquid lunch in The Flag & Whistle, we catch Myfanwy in charge of the return, which has now picked up the livestock vans,
and get back to Robin Square just in time to see one of the Heritage Loco's in action ~ Compton Steel in charge of "the resin rake" ;)
Nice simple battery power while I sat and enjoyed a cuppa! 8)
Really enjoyed myself, but I'm cream-crackered now! :lol:
Big Al
Post by Big Al » Wed Aug 28, 2013 9:43 pm
Nice photos The Earl looks a cracker, :lol:
Post by Chris Cairns » Thu Aug 29, 2013 12:32 pm
Greg, great to hear you are recovering nicely, and were allowed to run trains again. Those are some very nicely themed shots that you have shared with us.
Pity about not visiting the full size WLLR & the adjacent Garden Railway Show - just recently downloaded the YouTube video of the Resita destroying itself again!
