Archangel Range
cncmodeller
Re: Archangel Range
Looks like its just on the limit of that first radius curve! It's quite a long wheelbase, runs well though.
Here's mine on test.
https://www.youtube.com/watch?v=4S023PvSBig
Re: Archangel Range
A very nice steady runner by the looks of it. Stewart's safety valves do have a character all their own.
Merddin Emrys
Re: Archangel Range
What a stunning engine, love it!cncmodeller wrote: Fri Oct 12, 2018 1:16 pm Looks like its just on the limit of that first radius curve! It's quite a long wheelbase, runs well though.
cncmodeller
Re: Archangel Range
I've mostly finished my conversion set for the Vale of Rheidol 2-6-2 Edward 7th as GWR 1212 after it's 1925 rebuild, The GWR replaced it's side tanks to an identical pattern that is on the current trio apart from the small cut out for the valve gear, they also changed the safety valve cover too but I haven't got round to that.
The tank has etched and riveted overlays which are screwed to the top of the tanks and also a slither of steel is embedded in the brass so that the strong magnet inside the tanks holds it tight, this magnet doubles up to hold the original nameplates when running as Edward 7th.
The bunkers are CNC machined in brass and they fit over the original cab sides and works plate, in reality the original cab side was cut away by the Cambrian when they put larger bunkers on so forming a 'template' for the new GWR Locos no 7 and 8.
As regards colour the Locos are Deep Bronze Green BS381C 224 and I doubled checked by placing a colour swatch on 1213 recently.
John
Archangel VOR 2-6-2 as GWR 1212 002 by uniquenarrowgauge, on Flickr
Archangel VOR 2-6-2 as GWR 1212 001 by uniquenarrowgauge, on Flickr
John
Archangel VOR 2-6-2 as GWR 1212 001 by uniquenarrowgauge, on Flickr- IanC
Re: Archangel Range
John you have created some brilliant work on that loco.
Very impressed indeed. You should rightly be very proud...
Re: Archangel Range
That's lovely! It's still got a heritage charm but without looking out of place alongside modern locos, fantastic job.
