Joined up thinking
- Sir Clothem Cap
- Sir Clothem Cap
IRON MAN
TommyDodd
Depends on what you plan to do with them. If you're just going for an end-to-end then only width and track centres matter. If you want to retain the option of a circuit then standardised module lengths are suddenly more important, as both sides/ends have to be the same length or the curves won't meet. - And curve radii would need to be standardised too.IRON MAN:78363 wrote: Its no biggy really to have some longer than others?
- Sir Clothem Cap
I was thinking of the area available at peterborough and how curves added at ends would make a stretched s for future shows. A size limitation would also make a level playing field for all.
But if the module were not for judgeing in a show then the 'your railway your rules' apply. I would expect that most would desire portability so a standard length that fits into a standard car would be popular.
- Sir Clothem Cap
Lner fan Sam
- Sir Clothem Cap
TommyDodd
That would also re-open the "table-top or freestanding" question since you'd be into non-standard heights. Personally I like the idea of a standardized rail height above floor level, since that introduces the option of a drop baseboard to accommodate a tall bridge, like the Dolgoch viaduct on the Meltham group layout.
Hope Mountain Railway
Joined up Thinking
Guys, these module competition threads are getting away from my original idea. The Idea was for a super layout, to be built by a team of like minded people who might be spread over the country.
By default, these would have a common goal to build a Great Layout together. One that is capable of expansion when new people com on board. Each person trying to build modules that outdo each other doesn't help realise this goal. In my mind, one person, or a team of people might like to build a big complicated section, say a mine, or a harbour. Another person might really like to be involved, but not have the time to devote to something big and complicated. He might build 2 or 3 simple modules, say a small stretch of railway through a woodland. Equally important for the project as a whole, but difficult to judge compared to a complicated 'theme area' . Defined area modules are just too rigid in my view. Gareth
- Sir Clothem Cap
ahh, I see the modules as being as individual as you feel but being able to link to others by having common ends thus they can be used to build layouts at meets and shows and also be display tables for stock.
More the hotch potch than fixed themes althrough local area meets will develop a common style. The MOTY idea would be an incentive to build and display modules to build a large layout at such shows as peterborough.
A group themed layout is great but may struggle if a key module isn't present. This is all up to the individule or group concerned. If we can agree the end standards then all are able to add theirs at any time.
Last edited by Sir Clothem Cap on Sun Jan 06, 2013 12:22 pm, edited 2 times in total.
- Sir Clothem Cap
Here are the standards as stated by Gareth
End of board widths of 450mm and 600mm. Track centre is 150mm from front edge and further tracks at 150mm centres if reqd. Board height 75mm min. Nominal length for a standard module is 1200mm, but this by no means fixed, see forum chat. End of tracks from edge 50mm
Height from floor to track top 90cm
Thats enough to start building. Who is up for it?
Joined Up Thinking - Making a start
Hello All. Well, I have the timber, and have made a start on the first of the return loop boards. I'm at a stage now where I would like to gauge the interest in making modules and coming on board this project. There are some from this forum, some as a result of my SMT article, and others that are members of my Area Group, CMEC in N E Wales. One thing that I forgot to mention, is that I intend to name the system, 'Rowland's Modules', This after 'Rowland's Lodge', our group layout, originally built by my good friend John Wenlock (Membership No 0003), who wants to come on board.
Would all who are interested get in touch, and I will E-mail the pack of drawings and ideas that I have prepared.
Many Thanks, Gareth.
Joined up Thinking
First Baseboards are coming on well - John Wenlock will probably finish the first Straight Boards before I manage to finish the first return loop board - its a bit more complicated! ... Anyone else made a start? Gareth
- Sir Clothem Cap
