The Westwood & Loscoe Light Railway
Sir haydn
Post by Sir haydn » Fri Dec 02, 2011 1:33 pm
Brilliant.
The maroon suits her better than the green
Post by Narrow Minded » Fri Dec 02, 2011 2:01 pm
Cheers Matt, second time lucky ;)
I'm also really pleased with the "lift" that the clazing gives it over the basic model! :D
Pendo Pilot
Post by Pendo Pilot » Fri Dec 02, 2011 3:14 pm
Sir haydn:62249 wrote:Brilliant.
Was that aimed at me?? ;)
Looks good, even that colour can't spoil it. What you planning to add to it then??
Post by Narrow Minded » Fri Dec 02, 2011 4:04 pm
Don't think it was intentionally aimed at you Shane ~ 'tweren't GWR green 8)
It's desperate for either a horn or hatch on the roof (to cover the hole left by a flashing yellow LED.)
I'm knocking up a cab panel (which will also hold the speed controller I'm gonna fit), and then I'm just going to hang a bit more "clutter" on it before a bit of weathering ;)
Post by Narrow Minded » Thu Dec 08, 2011 11:24 am
The results of a recent bit of "tinkering" :D .....................
<object width="640" height="480"><param name="movie" value="http://www.youtube.com/v/0aG9EGhXjaI?ve ... ram><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/0aG9EGhXjaI?ve ... n_GB&rel=0" type="application/x-shockwave-flash" width="640" height="480" allowscriptaccess="always" allowfullscreen="true"></embed></object>
hussra
Post by hussra » Thu Dec 08, 2011 11:26 am
Narrow Minded:62654 wrote:The results of a recent bit of "tinkering"  :D .....................
Good stuff! <facebook>Where's the "Like" button on this thing?</facebook>
Richard Huss
in sunny Solihull
Sir haydn
Post by Sir haydn » Thu Dec 08, 2011 1:28 pm
Brilliant Greg!
Dr. Bond of the DVLR
Post by Dr. Bond of the DVLR » Thu Dec 08, 2011 2:48 pm
Did you record a sound sample onto those chips?
Post by Narrow Minded » Thu Dec 08, 2011 3:12 pm
Mr. Bond of the DVLR:62665 wrote:Did you record a sound sample onto those chips?
Yep! Trawled around on various sound libraries and such for both clips.
(I actually found a really nice Class 37 sound clip I was tempted to use!! 8) )
DolwyddelanLightRail
Post by DolwyddelanLightRail » Thu Dec 08, 2011 4:20 pm
I would have chosen the 37 clip! :lol: :roll:
Post by Dr. Bond of the DVLR » Thu Dec 08, 2011 4:59 pm
So you could produce one with the sound of an old tractor with an "ooogah" horn?
Post by Narrow Minded » Thu Dec 08, 2011 6:00 pm
Mr. Bond of the DVLR:62675 wrote:So you could produce one with the sound of an old tractor with an "ooogah" horn?
As long as the sound clip fits within a 10 second "loop time", anything. (for the main unit the clip duration can be lengthened at the cost of quality!)
At the moment, the ISD1820 is sending an End Of Message at the end of each cycle causing a tiny glitch during loop playback, but I hope I can sort that out.
Post by Narrow Minded » Thu Dec 08, 2011 9:24 pm
Keith&Joanna:62688 wrote:Codnor Castle looks suspiciously like its sadly departed cousin after its repaint at the Elmside Works  ;)
Agreed - in its "as arrived livery" :D (But trust me, that won't last ;) )
dougrail
Post by dougrail » Thu Dec 08, 2011 9:26 pm
Agreed! We did investigate whether it was or not the same engine...sadly, t'was not. My "Unknown" came from obscurity.
METHSSNIFFER
Post by METHSSNIFFER » Thu Dec 08, 2011 9:30 pm
Theres a shop in Birmingham that sells sound chips and the range is amazing I like the loo one the flush the f...t and the relief ahhhhhhhhhhhhhh,,
hussra
Post by hussra » Fri Dec 09, 2011 7:40 am
Like the idea of an 80-class sound unit for my under-construction DMU... http://www.youtube.com/watch?v=zlRsuc6zhSg
Richard Huss
in sunny Solihull
Post by Narrow Minded » Sun Dec 18, 2011 11:34 am
The P.Way gang have been busy as the W&LLR continues to attempt to get a quart into a (Half) pint glass!  :lol:
Leaving Westwood Station, the line now makes it's way through "The Alley" but now curves to the right.
Planting and/or rock (or building?) will block the view of the loop from Riddings in the distance.
The other end of "Mill Curve" (don't worry, I'll think of a more appropriate name once the scenic work gets established!).
Once the scenic block is in place, the converging line from Riddings shouldn't be seen / noticeable.
The Crossing - criteria; easy access for track clearing but hidden from most angles, looking from the site of the "new" Codnor Station it should give the impression of a junction.
The line then curves in to Codnor Wood. This was a "must keep" for the new formation, following the old trackbed through one of the most scenic sections of the line.
Plenty of scope for new planting! ;)
Leaving Codnor Wood, the old "R3" curves have been eased (R5), the tighter sleeper spacing will be lost under the Rowlands Mix!
Riddings Tunnel was another "no brainer" to keep and the line now leaves and curves past the halt. A new curved platform needs to go in here.
A few kinks but they'll be straightened before the ballast goes in - the new Codnor Station will be on the straight section with either a loop or new siding.
The old station building (a "Koala Brothers" toy house) will move to The Works Branch and be replaced with a new building.
Meanwhile, here's a last look at the soon-to-be-replaced Brinsley Lodge loco shed (Santa is bringing a Model Town one! :D ) before it's taken down and installed on "The Works Branch" to house the Simplex.
Unaffected by all the changes, Loscoe Station sits in a sea of tranquility - though there is a new lineside fence.  :D
Post by DolwyddelanLightRail » Sun Dec 18, 2011 2:44 pm
Cor, you've been busy! So where does that line go from the diamond crossing head off to/come from, is it just the mainline thats turned back on itself?
Post by Narrow Minded » Mon Dec 19, 2011 2:15 am
Cheers James ~ I actually had over an hour longer than I'd planned, since the missus went for a nap and locked me out in the garden! :roll:
Yep, it's the "main line" crossing over itself in a figure of 8. The works branch is in the vicinity though, so it should give the appearance of a subsiduary crossing the main ;)
I've been meaning to remove some tight curves, extend the run, and introduce some more "photogenic" points on the line and with the limited space I have this seemed the best option.
I managed to get some R5 curves and a crossover at great prices after the green light for the project from the household authority (currently known as "Sleepy")
Pendo Pilot
Post by Pendo Pilot » Mon Dec 19, 2011 10:34 am
Looking good fella, but I think we need a track map! Hope you have booked all the crews a nice 10 hour restday worked for road learning the new alignment! ;)
