Endless, Nameless
Post
by Endless, Nameless » Thu Dec 24, 2009 10:28 pm
It's quite heavy as it is, but I wouldn't mind adding a smidgen more low down. Wouldn't stick it in the box though, a.) full of radio gear b.) it'll wheelie everywhere
Getting the weight out of balance will actually make it worse.
Big enough engines not to look silly on a long train, especially with a cab fitted!
Last edited by Endless, Nameless on Thu Dec 24, 2009 10:32 pm, edited 1 time in total.
PCLR
Post
by PCLR » Thu Dec 24, 2009 10:31 pm
yeah fair point if but some in front of the gas tank
Endless, Nameless
Post
by Endless, Nameless » Thu Dec 24, 2009 10:33 pm
Aye, bottom of the sidetanks between the axles would be fine I'd a thought.
PCLR
Post
by PCLR » Thu Dec 24, 2009 10:34 pm
yeah and even under the smoke box
DolwyddelanLightRail
Post
by DolwyddelanLightRail » Fri Dec 25, 2009 9:36 am
I have been toying with the idea of weighing it down more because of my current incline! I don't know what the gradient of it is, but it rises up 2/3rds of the height of Edrig in 2 1/2 foot, if anyone can figure that out????
SillyBilly
Post
by SillyBilly » Fri Dec 25, 2009 12:15 pm
mhlr wrote:It would also look silly a 'little' 0-4-0 pulling a train the length a Garratt would be likely to haul!
You don't need to add weight for that!
MoelygestLR
Post
by MoelygestLR » Fri Dec 25, 2009 5:45 pm
SillyBilly wrote:mhlr wrote:It would also look silly a 'little' 0-4-0 pulling a train the length a Garratt would be likely to haul!
I thought you might add your opinion to that at some point.
he is of course reffering to the time when his edrig pulled TonyW's standard rake of wagons he pulls behind his Garratt
SillyBilly
Post
by SillyBilly » Fri Dec 25, 2009 6:14 pm
MoelygestLR wrote:he is of course reffering to the time when his edrig pulled TonyW's standard rake of wagons he pulls behind his Garratt
Actually I was reffering to the time it pulled Tony's coaches & wagons, some 64 axles from memory.
MoelygestLR
Post
by MoelygestLR » Fri Dec 25, 2009 8:17 pm
SillyBilly wrote:MoelygestLR wrote:he is of course reffering to the time when his edrig pulled TonyW's standard rake of wagons he pulls behind his Garratt
I bet Alicia would cope with that quite easily
Well hopefully Linda will do or doublehead and it will be easy!
SillyBilly
Post
by SillyBilly » Fri Dec 25, 2009 10:13 pm
Tony didn't reckon a standard Roundhouse loco would do it, but 'Monarch' did because of the extra weight added by coalfiring.
PCLR
Post
by PCLR » Fri Dec 25, 2009 11:00 pm
i don't know about that my friend got a roundhouse russle (i have fix it twice, bloody thing )And my edrig out pulls it easy hi had 12 wagon max and i had 20 wagon(ran out of stock)
MoelygestLR
Post
by MoelygestLR » Fri Dec 25, 2009 11:56 pm
SillyBilly wrote:Tony didn't reckon a standard Roundhouse loco would do it, but 'Monarch' did because of the extra weight added by coalfiring.
Well i guess we will just hve to wait and see
Alicia was pulling quite an impressive load at rattys xmas steam up!
SillyBilly
Post
by SillyBilly » Sat Dec 26, 2009 1:18 am
MoelygestLR wrote:Alicia was pulling quite an impressive load at rattys xmas steam up!
Nothing compared to this (
http://gardenrails.myfreeforum.org/about1339.html ) and you know how well weighted Tony's stock is. Not bad for £400s worth of loco!! Two years old now too, how time flys when you're having fun, I guess it's better than doing nothing!
PCLR
Post
by PCLR » Sat Dec 26, 2009 10:12 am
i bet you got loads of wheel spin which is wasting steam
SillyBilly
Post
by SillyBilly » Sat Dec 26, 2009 11:41 am
Only at first, as soon as the oil wore off the treads and it found it's feet, it was away, then I used the top up valve to maintain a healthy water level.
MoelygestLR
Post
by MoelygestLR » Sat Dec 26, 2009 4:08 pm
Linda will pull that lot!
By the way look at my Linda thread!
