Question....
laurence703
I've sussed it! Its not exactly brilliant but its a good option if you don't fancy drilling more holes in your loco...
There's a gap between the smokebox and the burner box area just wide enough to slide a piece of thin copper pipe through... So what I've done is bend a piece of copper pipe with a 90 degree bend in it and push it through the gap and then pushing it so it sits just above the other cylinder. The other side where the modification is has the copper pipe bent around the pipe with the wire in it to form a loop and as the wire only forces the pipe outwards it acts as a shepherds stick and stops it from moving outwards.
I'd post pics but I'm not sure how...
laurence703
I have attempted to attach it to a reversing lever to find that the wire I'm using likes to bend sideways when trying to put it in forward, yet works fine in reverse! I've taken the wire off for now to re evaluate the situation... but on the plus side, it now has a rather nice little dummy reverser in the cab!
Any ideas?
Any ideas?
spooner
laurence703
- Sir Clothem Cap
Charles M
Go over to the Mamod site :
http://modelsteam.myfreeforum.org/about ... 257b3daf02
I have posted an article about how to fit R/C to a Mamod and show the bell crank that I made to cotrol F/R on the engine.
Charles M
Charles M
- Superbiker_uk
Merlin supplied a bell crank arrangement for controlling the regulator using r/c although it could be easily used to put the forward/reverse control into the cab using a lever and quadrant arrangement like an Accucraft. Merlin produced this set up for the Mamod back in the 1980's. I got hold of one and fitted it to a Mamodification called "Ronald".
I can scan and upload the Merlin instructions if there is any interest?
laurence703
- Superbiker_uk
http://gardenrails.myfreeforum.org/about5082.htmlI would be interested in seeing the instructions.
laurence703
- Superbiker_uk
