bridget has done some heavy milage so has come in for a full service
In The works
- andysleigh
Sir haydn
- andysleigh
Sir haydn
After Dereks 'little' fire this loco has now had a full new radio control set added and the lining lost. the trimline couldnt handle the heat and flaked off. Once iv trial run the loco lining will be re-applied. some of the paint was scortched, most of this has been polished out using a high grade cutting paste.
Sir haydn
DVT Dweller
Sir haydn
Sir haydn
Its a rebuild job, It came in a box in pieces. totally stripped down with no instructions or pictures. I have buit it up to the state you see there purly from the odd photo i have found. Only the chassis is partually completed at the moment and i have used a pair of milton valve chests. I have a pearse lubricator regulator combo block which was used in the old countess which will replace the worn out merlin reg block. It will then be lined and prettied up.
The loco has sat in bits for 17 years, and was built in the early 80's so is older than me!
