It seemed to flop sideways too far for my liking.mikewakefielduk@btinterne:123602 wrote:Do you need one at all? I discard mine and rely on the servo to hold the reverser in position.and fitted a much lighter friction spring
Ragleth; adding radio control
- Boustrophedon
- Chris Cairns
Glad I stopped by with this Topic as I've now got a couple of 'To Do' items completed.
4 x AAA battery holder now fitted to the Ragleth, replacing a 4 x AA battery pack, making it more accessible for recharging/removal. Finally cut an extra slot in the display board so I can now store this loco in 32mm gauge in the Accucraft box.
Tried fitting a flat 4.8V AA battery pack to the Edrig inside the right side tank but it fouled operation of the reverser. So flat 4.8V AAA battery pack fitted, so no requirement to carry the battery pack/holder in an attached wagon.
I can understand your sentiment regarding metal geared servos, but so far I've not stripped any of my servo gears - all plastic/nylon. Roundhouse fit Hitec HS81 servos to some locos, and if you are fitting a Roundhouse radio control kit to your loco it will probably specify HS81 servos. The problem with all these cheap generic servos being flogged from Asia is that many do not provide all the relevant sizes so you do not know beforehand if you will have fouling problems.
- TonyW
HS82MG are the equivalent to HS81 but with metal gears.
- Chris Cairns
Re: Ragleth; adding radio control
Briefly discussed this subject at last weekend's running day.
What seems to be missing with some of these generic/unbranded servos is proper dimensions (not just the mounting holes), so you can work out a direct replacement for the HS 81 (or HS 82) when there is no stock of the Hitec servos available (as was the case when I was looking for some last year - I guess they were waiting on a ship delivery from Asia). I spent some time searching some Radio Control Forums & Traders websites but could not locate a non-Hitec direct replacement for the HS 81. Eventually more HS 81 stock arrived.
- Boustrophedon
Hmm! Coming to this as a noob, I had no idea which of the 1000s of servos on offer to use. So I looked at the utterly cheap, blue 9g servos I used for my foamboard RC planes. I looked at the specs and measured the force needed to move the controls on Ragleth and bought some better versions with full metal gears, about £5 each. They are much smaller but have more than enough torque to work the controls on Ragleth. How long they last we shall see.
No Ragleths were harmed during the making of... (No holes drilled.)
Batteries in the usual place under the floor, switch in the right hand hole, charger plug in the left.
(pictures uploaded using the drag and drop method.)
Last edited by Boustrophedon on Mon Apr 03, 2017 10:08 am, edited 1 time in total.
- Boustrophedon
I understand why Roundhouse et al use such big servos, moving a full or semi Walschaerts takes some effort, but the Ragleth control valve takes hardly any force to move.
I have to say just how much nicer a Ragleth is with full RG. I tried it on reverser only but throttling it down, whilst it works is very noisy, so much nicer to have the throttle on RC as well.
- RSB
Could someone please tell me the type of Futaba servo commonly used on the reverser of a Ragleth / Mortimer / Caradoc loco?
I used a S3001, more than enough for the job.RSB wrote: Fri May 12, 2017 7:30 pm Could someone please tell me the type of Futaba servo commonly used on the reverser of a Ragleth / Mortimer / Caradoc loco?
I use a Tower Pro SG90 micro servo on the reverser on one of my Roundhouse chassis locos...Boustrophedon wrote: Mon Apr 03, 2017 10:07 am I understand why Roundhouse et al use such big servos, moving a full or semi Walschaerts takes some effort, but the Ragleth control valve takes hardly any force to move.
- RSB
thanks
