Deltang Tx20 kitbuild
Post by -steves- » Fri Nov 06, 2015 10:52 am
Glad you have it all sorted now :)
I have managed to overcome most of the issues I was having before too. No wiring problems, a couple of hardware problems, a couple of programming issue and a mis-calibration so far. Although obvious once you know, the regulator / speed control on the TX24 must be calibrated at centre point, though centre point is hard to guess and there is no indent for it. If you calibrate this with the throttle off, it gives all sort of strange occurrences.
I resoldered my TX24 up, thought it was lookin much better than the original.  http://www.16mmforum.co.uk/viewtopic.php?f=26&t=3
As you can see I also added another switch into the equation on ch7. Just have to programme it up properly now
Looking forward to seeing your video of it all working :) :D
